building a well
   / building a well
stimw that's exactly what im talking about using mud pump to reuse water since I don't have water supply
   / building a well #12
If you cut teeth in the bottom piece of 2" PVC you can rotate it and it will work better.
I put female ends on the 2" X 10' PVC and used a steel nipple between them for more strength. You need "U" fittings at the top so the hose doesn't kink.
I had trouble with the garden well. I got down 18' with a garden hose and could not go farther. I dug a pit with my backhoe and put a piece of plastic in it so the water would run back into it so I could re-use it. I used a 2" pump from the pit to the pipe and it took 5 minutes to wash down the last 12' !!!!
2020 VOLVO VNL TANDEM AXLE SLEEPER (A54313)
2020 VOLVO VNL...
2001  WABASH 53FT DRY VAN TRAILER (A54607)
2001 WABASH 53FT...
UNUSED RAYTREE RMT48 HYD TRENCHER (A54757)
UNUSED RAYTREE...
2007 FORD F150 XL EXT CAB TRUCK (A51406)
2007 FORD F150 XL...
2014 Ford F-550 4x4 Terex Hi-Ranger LT-40 40ft Insulated Bucket Truck (A55788)
2014 Ford F-550...
2017 KUBOTA RTV-X1120D (A54756)
2017 KUBOTA...
