gsganzer
Elite Member
- Joined
- Jun 11, 2003
- Messages
- 3,274
- Location
- Denton, TX
- Tractor
- L3800 w/FEL and BH77, BX 2200 w/FEL and MMM
Eddie,
Why do you need piers at all? I've seen some boat houses on Possum Kingdom and very few of them have piers. The entire boat house floats (same as you intend), but the boat house is kept out from the shore by the walkway and two trusses. The walkway is in the center and the trusses (20 feet long or so) attach to each corner of the boat house and anchor back to the shore. The trusses usually angle from the shore to the boathouse (sort of triangulate) to keep the boathouse from drifting left to right. This allows the boathouse to rise and fall with the lake level. The only change is the angle of the walkway to the boathouse as the lake level rises and falls. The trusses and walkway are all hinged at the boathouse and the shore to allow up/down movement.
I don't know if all that makes sense, but I can draw a sketch if you want.
Weld all the components up and then send them to a galvanizer. I have some galvanizers near Dallas if you need names. One note: If you have the parts galvanized, drill all the tube and/or pipe members (minimum 5/8" holes) so you get galvanized inside and outside.
