beenthere
Super Star Member
- Joined
- Aug 16, 2001
- Messages
- 18,611
- Location
- Southern Wisconsin, USA
- Tractor
- JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold)
Timd Would you mind explaining to us why you want 1/4 sawed 2x4 and 2x6 material? I ask, because the limbs on the tree (which are usually large diameter on white pine) will saw out in 1/4 sawn material as spike knots, which are across the full width of the face. Flat sawed material will produce knots that are straight through the thickness (1 1/2") and are round.
Also, often nails in trees are the excuse (not the real reason) that sawmills don't want to saw home logs. In reality, only a portion of the log volume ends up in quality, usable products which is a disappointment to the person who has the logs - i.e. a log scaled 100 bf, but may saw out only 50% in usable 2x4 and 2x6's. Thus the sawyer gets less out of the logs than is expected. Logs vary in quality, depending on how the trees grew, and how many limbs were pruned off early in the growth cycle of the tree.
Its tough to get just a specific product out of logs, as a typical log has some construction grade or dimension (2x's), and some boards. Also, a log may have some very low grade in the center that is best boxed into a timber (3"+) for any recoverable value. If the log owner only wants construction material in 2" dimension, will the rest of the log be waste (firewood, etc.), or will the sawmill get to saw that material into a saleable product?
