Bump up lift capacity of L3400/LA463 Loader
   / Bump up lift capacity of L3400/LA463 Loader #21
2700-2800 would about be my max. If you want more grunt, get some 2" diameter cylinders.
   / Bump up lift capacity of L3400/LA463 Loader #22
I'd be more curious to learn what it will do to/for the drive systems on the HST's. Running it over rated pressure could cause more problems then its worth.
just my $0.2..
Jim
   / Bump up lift capacity of L3400/LA463 Loader #23
Would this modification also increase the TPH lift capacity?
   / Bump up lift capacity of L3400/LA463 Loader #24
just my $0.2..
Jim
No impact. Separate systems, only thing in common is the fluid. The pump for loader and 3pt is on the side of the engine. The 2 pumps for the HST are in the transmission case.
jb
   / Bump up lift capacity of L3400/LA463 Loader #25
Thanks for the input! Mine will remain at 2750 and works just fine.
   / Bump up lift capacity of L3400/LA463 Loader #26
Yes, the relief valve for the loader is the same one for the 3pt hitch. Don't expect massive gains. Unless your relief was tired and you then go from 3-400 psi under spec to 200 over spec.
It is important that you use a gage to measure the pressure, don't just guess that it was low and add a wad of shims. That wouldn't be smart.
jb
I now have a 5000 psi wet gauge in hand and just need to figure out the fittings to hook it up. I will post when I have more information. Brian
   / Bump up lift capacity of L3400/LA463 Loader #28
Brian,
Sounds like you are well on your way. I am interested in what you find out about the proper fittings needed to put your guage together... I need to do the same. Pictures, part numbers... anything that would help the rest of us put a guage together, would really be appreciated. I look forward to your end results also... I know my L3400 with LA463 loader is a bit weak on the lift capacity, and I'd love to improve it. Thanks for keeping everyone posted.
   / Bump up lift capacity of L3400/LA463 Loader #29
If you can just hook it up to the bucket hydraulics, all you will need is a quick-disconnect fitting like the one below. I think the quick disconnects used on the bucket hydraulics are 3/8" ISO Series B fittings.
Quick-Disconnect Couplings
Part# 95825K82
   / Bump up lift capacity of L3400/LA463 Loader #30
What affect would this have on a bh75 hoe?
Actually just bumping the thread..:D
8' X 42" X 10' PALLET RACKING (A58374)
8' X 42" X 10'...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2018 Ford F-150...
2019 VOLVO VNL64T860 TANDEM AXLE SLEEPER (A58018)
2019 VOLVO...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A55745)
2013 ORTEQ ENERGY...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
