Burned ECU board pics-4110
   / Burned ECU board pics-4110 #21
To answer various questions:
The purpose of this board is to integrate various safety switches (seat, PTO, neutral positions) and either supply or deny 12 volts to a fuel shut off solenoid. There is a separate voltage regulator elsewhere.
Didn稚 know the low DC voltage (either 9VDC or 1.5VDC) of the ohm meter could damage the simple 3 legged transistors populating the board and designed to have 12VDC pass through them.
The theory of operating part of the shop manual says the circuit that痴 behaving sporadically (provides 12v for 1 second to a solenoid coil) does so by providing a path to ground for one second. Any ideas on what component to look for that would perform this task?
Possibly a simple R/C time constant (resistor capacitor) to trigger the control of the transistor driving the solenoid coil. as others have said- speculation without a schematic.
That board is burned pretty bad in places, probably been hot enough to separate and burn open some traces too...
2017 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51246)
2017 CATERPILLAR...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2022 John Deere HD45F Draper Head (A53342)
2022 John Deere...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A53472)
2012 RAM 5500...
