Burning wood , Add-A-Furnace; Monarch, Longwood
   / Burning wood , Add-A-Furnace; Monarch, Longwood #1
Theowegian
Emporia, Kansas
Kubota L3130 HST
Anyone have a wood burning furnace which is tied into the gas furnace?
I have one-installed new with the house in 1975. The wood furnace an old Monarch brand, called Add-a-Furnace. Parts are extemely hard to find, but Ive found a few. Ive heard and seen a few Longwood furnaces, too.
Just wondering if anyone has a wood furnace that they purchased or built or if anyone is familiar with Monarch or Longwood?
dwight
Longwood brand furnace.
/forums/images/graemlins/smile.gif
   / Burning wood , Add-A-Furnace; Monarch, Longwood #5
Dwight,
I'm not familiar with either. I have a LTD Limited add-on furnace which I bought about 15 years ago used. The door says Osseo WI on it. Uses a small Dayton squirrel cage blower. Up until last year I had it in my shed. I replaced it with the idea that I would move it down to the house and tie it into our existing H.E. forced-air gas furnace.
That plan has gotten waylaid a bit for several reasons:
1. I would need to move my existing furnace from where it sits. The estimate for our local HVAC company to do so was around $500 to $750.
2. I currently have a natural gas water heater which vents into the flue I would use, so I would probably need to move it and/or come up with a different venting scheme. More $$$.
3. The basement room where I would be locating the addon doesn't have a door to the outside, which makes getting wood into it a bit of a problem. (The only path is thru a family room in the which currently has a white berber carpet /forums/images/graemlins/grin.gif)
4. I already have a woodburning insert in the basement fireplace - although it isn't the greatest unit (it's a Good News), it does provide a significant amount of supplemental heat.
5. We're putting up a polebarn (they start tomorrow) and I'm thinking of just locating the unit there.
One of the things I did after pulling the unit out of the shed was to "port & polish" /forums/images/graemlins/grin.gif the draft vent to open up the holes in it. When I had it in the shed it was always starving for air - in order to get the fire going good in it you had to open the ash cleanout tray slightly to give it enough air - hopefully it will work a little better now. One of the problems with the design of this unit is that they ash cleanout tray does not have a door that locks closed on it - the tray just slides in and out. It would be very easy to over-fire it if you weren't careful.
Attached is an image.
   / Burning wood , Add-A-Furnace; Monarch, Longwood #6
Dwight -
I used a Monarch Add-A-Furnace for twenty years hooked up just like yours. I burned about twenty face cords of wood a year and not much propane . I thought the furnace was pretty darn good. I did have to replace the cast iron liner plates a couple of times, but the last time I tried to replace them, my dealer told me he couldn't get them anymore.
When we were getting ready to sell our house, I replaced both furnaces with a high efficiency gas furnace, and the old Monarch was carted off to the scrap yard.
Tom
   / Burning wood , Add-A-Furnace; Monarch, Longwood #7
When I eventually relocated my old add-on to my barn, I removed all the shrouding, insulation and the blower, so I didn't have to have that noisy blower going all the time. To provide a little better air circulation, I put a ceiling fan in the ceiling above and have it on low speed. It not only helps to distribute the heat, but also does a better job at keeping the whole barn warm, and its oh so quiet. I've only got 3-1/2 inches of insulation in the ceiling, but it's not uncommon to get my 30x40' barn up over 70 degrees.
Tom:
Thanks for taking time to reply to my post.
I visited the heating/ac dealer this week that originally installed my Monarch in 1975. He actually remembers the install. Anyway, I asked him about replacement parts because I was thinking about refurbishing it or maybe replacing it with a newer stove.
The dealer offered me one option.
1-Install new side plates...$100 a piece (he has some and showed them to me)
But I wondered if buying a whole new wood furnace, like the Yukon Eagle Add on Furnace. Im wondering if that might work for me? The payback would be about 3-5 years.
I burn about 3 full cords of wood per year and cut my own wood, my house is 1800 sq ft plus full walkout basement.
So, I guess Im still exploring my options....if you have some possibilities, feel free to let me know.
dwight
   / Burning wood , Add-A-Furnace; Monarch, Longwood #9
We have a wood furnace just like yours which we bought from an individual when we built our house in 1995. We live near Cassoday and would love to know of a local dealer for parts.
Jean
   / Burning wood , Add-A-Furnace; Monarch, Longwood #10
My B-I-Ls new log cabin has a wood-burning add-on furnace made by FireChief. Works great!
Obadiah's Furnaces
- Jay
2014 International Durastar 4300 Terex BT3063 63ft 15 Ton Crane Truck (A50323)
2014 International...
1000 Gallon Concrete Fuel Tank (A50774)
1000 Gallon...
2014 Bobcat 15C Skidloader PHD (A50774)
2014 Bobcat 15C...
Chery 10' 18 Drawer Workbench (A50121)
Chery 10' 18...
2004 Ford F-350 Reading Service Truck (A50323)
2004 Ford F-350...
2022 Robex 55-9A Midi Excavator (RIDE AND DRIVE) (LIKE NEW) (A50774)
2022 Robex 55-9A...
