Bush Hog blade sharpening
/ Bush Hog blade sharpening #21
y'know Bird ..., it wasn't 3 minutes after I posted that message that I realized I had mospelled his name.
Muhammad ... my apologies ... that's what happens when I get too "tongue-in-cheek".
I bow my head and meekly accept the demerits!
/ Bush Hog blade sharpening #22
That was a nice touch, though: Muhammad will probably cancel the demerits because you mis-spelled your own name to make up for it. /w3tcompact/icons/wink.gif
Mark
/ Bush Hog blade sharpening #23
Peter,
I changed you to 'member' since I have seen you around for a while... as for the spelling of Muhammad; several spellings are acceptable, but I spell it Muhammad. No problem there.
/ Bush Hog blade sharpening #24
heck, Muhammad ... I was just poking some gentle fun at my fellow orange-lovers! I spend far too much time online as it is .. I wasn't looking for a "free" upgrade.
I follow most of the threads every day (even when I have to spend a week out here in California) and learn something new everyday ... but after making dumb comments about "live" pto's ... I just sit quietly unless it's a subject like computers, warehousing or riding my 'wing ... where I actually know something ...
peter
too bad that common sense ain't
/ Bush Hog blade sharpening #25
Peter, you were only one post away from Member as it was!
/ Bush Hog blade sharpening #26
Just remember this when sharpening/balancing Blades on a bush hog...ie...2 separate blades, spinning from the same point. The only essential balancing is going to be that the blades are of the same weight. The central point of the bush hog will only feel the imbalance if blades weigh a different amount. If you are going to balance the blades, they will HAVE to be OFF of the bush hog, and you will balance them against one another. In other words, if both of the blades weigh the same amount, the blades are balanced. If one blade weighs more than another one, then you will feel it...the gearbox and everthing will pay the price for blades that are out of kilter.
Hope that makes sense.
/ Bush Hog blade sharpening #27
Makes sense, but I just touch up the edges of the blades with a grinder while they're on the cutter.
/ Bush Hog blade sharpening #28
VERDICT, thank you. Now I understand.
John Deere 561M Baler (A63111)
John Deere 561M...
2012 International (A59230)
2012 International...
2 new 10'' Pallet fork extensions (A61567)
2 new 10'' Pallet...
2016 FREIGHTLINER CASCADIA 125 T/A DAYCAB TRACTOR TRUCK (A59912)
2016 FREIGHTLINER...
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A63689)
Greenworks...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
