Bush hog for 2910
/ Bush hog for 2910 #1
Anonymous Poster
Epic Contributor
Is the woods model xti60 good for the 2910? My dealer said the mdi60 could also work but more$$$. Is the mdi60 or xti60 the better of the two?
/ Bush hog for 2910 #2
Depends on a few things.
I'm not that familiar with Woods products, other than they are well regarded and of high quality.
You don't give us much info on your tractor - Is it a gear drive, or hydrostatic?
A 60" cutter will probably work fine either way, but it depends upon what you're cutting. If you are doing heavy cutting (saplings, bushes, etc.), you may wish for a smaller cutter, or a bigger tractor. If it's mostly pasture and weeds, your tractor (assuming it's 29hp) should do just fine with a 5-footer.
The dealer most likely is pushing the one on the lot vs. what may need to be ordered.
I used a King-Cutter cheapo for 5 yrs, but a Woods is a Cadillac in comparison . The KK worked just fine though...
Lunk
/ Bush hog for 2910 #3
Fourteen years forty days - is that a record?
Jim
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63118)
2021 Takeuchi...
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
2018 HINO 258A REEFER TRUCK (A63569)
2018 HINO 258A...
2013 FORD F350 SUPER DUTY 4x4 CREW CAB PICKUP TRUCK (A59910)
2013 FORD F350...
2013 FREIGHTLINER CASCADIA (A63569)
2013 FREIGHTLINER...
Adams Under Truck Conveyor (A63118)
Adams Under Truck...
