Bush hog gear oil
   / Bush hog gear oil #1
goat
Great State of Alabama
Massey 281xe
I bought a new 8 foot bushog about two years ago. I use it to cut about 50 acres of tall grass every year. How often to I need to check or change the gear oil in it? Any advice of how to change it ?
Thanks Ed
   / Bush hog gear oil #2
What does your manual say to do?
If it doesn't specify, ask the dealer you bought it from...
   / Bush hog gear oil #3
My Woods BB60 Brush hog is 3 years old. I generally check the gear oil at the beginning of each mowing season, and maybe once during the season. During the mowing season, it's on the tractor frequently, and gets parked in a garage with a cement floor... this lets me quickly see (by any spots or puddles on the floor) if any of the seals are leaking. If not for that, I might check more frequently.
The area I mow is pretty rough. I hit a lot of stumps and rocks. If it was just grass/meadow without all the obstructions, I wouldn't check even as often as I do. (I'd rely mainly on the "puddle on the floor technique" to tell me when I was losing some)
John Mc
   / Bush hog gear oil
Unfortunately, my dealer said he would mail the manual and never did.
   / Bush hog gear oil #5
I've heard of that happening lots of time. I'm sure they get busy and just forget.
If it's a Bush Hog brand you can go to their site and download the manuals for your mower.
I'm sure that some other mfg's allow you to download their manuals as well. Just do a search for the brand you have.
   / Bush hog gear oil #6
Some people run a double ought "OO" grease in gear boxes, they run cooler and do not leak when the box temperture is up. Also if your running the gear box on the higher side of the HP range it will increase the life of the box.
Chuck M.
17301 (A55853)
17301 (A55853)
2006 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A52707)
2006 CATERPILLAR...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A55851)
Miller Trailblazer...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A53421)
2017 JLG Skytrak...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
2013 Club Car Carryall 252 Electric Utility Cart (A51694)
2013 Club Car...
