Rotary Cutter Bush hog Model 2[emoji[emoji6[emoji640]2][emoji640][emoji640]][emoji6[emoji640]2] Deck Repair
   / Bush hog Model 2[emoji[emoji62]][emoji62] Deck Repair #21
Being the welder I have is light duty, I may go this route. No sentimental value, just an equivalent bush hog is 3k, not really in the budget.
Good used rotary cutters can be found for MUCH less than that. Some may need a little work but nothing like the that green rust bucket.
   / Bush hog Model 2[emoji[emoji62]][emoji62] Deck Repair #22
Good advice. Around here you are able to find something for around $1200. I have an old 5' IH which I will be selling for less than that because it needs blades and a stump jumper.
   / Bush hog Model 2[emoji[emoji62]][emoji62] Deck Repair #23
…about an equivalent $3,000 Bush Hog not being in the budget, I SIR COMPLETELY UNDERSTAND!
When I’m able to buy a bush hog, I think I’m gonna go with the King Kutter at Rural King. The RK branded King Kutter is on sale now at RK and can be shipped to your door. Plus you can add a slip clutch if you want, or buy a model already with the slip clutch.
2011 DODGE CARAVAN (INOPERABLE) (A53843)
2011 DODGE CARAVAN...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
35176 (A53424)
35176 (A53424)
1999 CLEMENT END DUMP (A53843)
1999 CLEMENT END...
