Rotary Cutter Bush Hog & Woods Dual Spindle Cutters
   / Bush Hog & Woods Dual Spindle Cutters #11
Mike
Could a double action sickle bar mower work?
Just a thought.
Re: SQ84T
OK, I don't think we wanna spend 2 grand on this ine... Now if I get one for $500....
Sickle mower? I dunno... We have some rocks (soft sandstone) and light brush. Are they up to that? Do they require much maintainance? I know nothing about sickle mowers...
Re: SQ84T
Well, I am going to try and decide between the Deere LX6 and MX5. For Now... (No promises, I couls end back looking at others....)
Since that is all Green, and I want some input from owners of mid chassis Deere's, I'll start a thead in JD O/O
Thanks!
   / Bush Hog & Woods Dual Spindle Cutters #14
Re: SQ84T
I've seen some bent up to but I also know how it happened and who was driving and that told the story. The size of the tractor on the front of it does make a difference also. You don't feel to much with a 80 horsepower tractor on them either.
   / Bush Hog & Woods Dual Spindle Cutters #15
A 4310 E-Hydro will not handle a 80 inch machine...72 is max for light to medium conditions.
edv
   / Bush Hog & Woods Dual Spindle Cutters #16
EDV
If you don't mind where in SC are you?
Paul
   / Bush Hog & Woods Dual Spindle Cutters #17
depending on your width of tires stick with a 5 to 6'. I would like to see a loader for ballast.
<font color="green"> A 4310 E-Hydro will not handle a 80 inch machine...72 is max for light to medium conditions. edv</font>
Well, I decided against the Woods (No Way It'd work)
I am almost certainly not going with the Bus Hog. Even though it is 720lbs and rated for 25 Hp, I am not convinced that I wouldn't have trouble with it due to the frame on an offset model. I am really not ready to gamble $2000 that way. I can't seem to find any, and would have to special order it.
Hey edv, can you answer this:
The description I have read for the MX5 suggest that it cuts faster due to its design. Will I cut faster with the MX5 or the LX6? They are roughly the same price, locally.
   / Bush Hog & Woods Dual Spindle Cutters #19
Just to add some fuel to the fire...
I have very good success running a Woods RM600 (72 inch, 3 spindle) mower behind a Kubota B2400 (18 hp at the PTO). This arrangement will perform well when cutting 12 inches of VERY thick pasture grass (in one pass). It also does real well in 4 feet of thistles, bachelor's buttons and other tall weeds.
The blades are kept at factory specifications (razor sharp). I set the engine to PTO speed, place the transmission in low range, and hold the hydro-pedal at full speed. The front loader is not needed for weight on the front either.
2012 FREIGHTLINER CASCADIA (A52472)
2012 FREIGHTLINER...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
JOHN DEERE 8R 280...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
