Bush Hoggin' with dew on the ground
   / Bush Hoggin' with dew on the ground #11
Re: Bush Hoggin\' with dew on the ground
Looks like the bottom line is:
When there's dew, pay due heed, and do it safely, less you be in deep doodoo. /forums/images/graemlins/grin.gif
...Tony
   / Bush Hoggin' with dew on the ground #12
</font><font color="blue" class="small">(
If you guys need rain just move to Alabama... we've had rain everyday for the last 2 months. Okay... maybe it skipped 2 days in those 2 months. It's been ridiculous.
I've had no choice but to cut with the ground wet. The only thing I don't like is having to clean out under the deck... when it's wet it sticks and builds up quicker. Of course you could run over a road of gravel/rocks and clean it out fairly quickly. )</font>
You aint lyin! Alabami has been WET!
I've been waiting and waiting on SEVERAL projects for the rain to break enough, but I tell you what...at least it doesn't feel like the Sahara like it does some years.
As far as the dew goes with the bushhogging, I'd say that's just about the best time to cut unless it's extremely wet.
It's a little cooler and the Bahia cuts well wet. Broadleaf weedy grasses clump some, but it doesn't do any damage unless you leave it on and let moisture rust the underside of your hog for years on end.
Remember to keep your PTO shaft and gearbox lubed/greased to keep moisture out.
   / Bush Hoggin' with dew on the ground #13
Yes, definately keeps the dust and pollin down.
   / Bush Hoggin' with dew on the ground #14
Yea, and sometimes a man's just /forums/images/graemlins/grin.gifgotta dew what a man's gotta do
   / Bush Hoggin' with dew on the ground #15
This seems to be much a-DEW about nuthin /forums/images/graemlins/wink.gif
Everything is softer in the dew of the morn'in
   / Bush Hoggin' with dew on the ground #16
I missed this thread somehow. For us, the only holdback is the slopes. My brother broke the front axle off a new IH 806 back in the 60's bush hogging on a slope. Once it started to slide on the wet grass there was no slowing down till it hit bottom going straight down. I don't think he intended to bush hog all the way down that hill.
2430 (A51248)
2430 (A51248)
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
2007 FREIGHTLINER COLUMBIA 120 (A55745)
2007 FREIGHTLINER...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A55852)
2012 Freightliner...
Adams 6T Fertilizer Spreader (A55301)
Adams 6T...
