Buying a used plow
/ Buying a used plow #1
Sideways
Southern Maryland
I am buying a used Kubota single bottom plow that has supposedly only been used 1 time but has been sitting outside for the last 3 or 4 years.
What do I use to clean up the moldboard so it plows efficiently as possible?
Going with a single bottom since my compact tractor is rated at 17hp
/ Buying a used plow #2
single is the right choice for your 17hp.
use either a cup wheel on a grinder or my favorite, one of the flap sander disks for a grinder to clean off the surface rust.
whatever you dont get with the grinder will be taken care of within the first 100' or so of plowing.
I spray a light coat of paint on mine in between uses as paint comes off easier than rust durring the next use.
/ Buying a used plow #3
what he said.....or if you have some sandy / gravely land that will put a good shine on the moldboards too. ;)
/ Buying a used plow #4
Plowing with it will polish, wear the rust off, in no time at all.
Otherwise a rotary steel brush on the end of a drill will remouve it in short time, or a cup wire brush on a hand held grinder.
Good luck and enjoy.
/ Buying a used plow #6
Bad idea, once it gets worn off, when you are done with it put a thick coat of grease on it.
You could also sand blast to remove rust...
/ Buying a used plow #7
I always used grease to coat the moldboards after plowing for the season, but it is a messy job. This year I had a partial can of spray paint on the bench at the time, so I grabbed that to try rather than grease. It was much easier, and from now on I will use old spray paint.
/ Buying a used plow #8
I use Fluid Film and don't worry about it. Any rust is gone after a short time in the ground.
Here is the single bottom plow I picked up.
Since I am a newbie, can someone tell me the best way to adjust the plow? :eek:
/ Buying a used plow #10
I just plow. Rust comes off in a pass or two.
43018CFL (A59228)
43018CFL (A59228)
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
2022 EZ-GO ELITE...
2017 Nissan Sentra SR Sedan (A61574)
2017 Nissan Sentra...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
