jeff9366
Super Star Member
- Joined
- Jan 14, 2011
- Messages
- 12,787
- Tractor
- Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
Traditional Three Point Hitch tractors are inherently unstable operating on sloped ground. Tractor rear wheel/tire spread, sometimes adjustable, is a critical factor increasing compact tractor stability working sloped or uneven ground. A 6" to 10" wider rear axle substantially decreases tractor rollover potential.3
T-B-N ARCHIVE:
TRACTOR FOR STEEP HILLS SLOPES MOUNTAINS site:tractorbynet.com
When considering a tractor purchase, bare tractor weight first, tractor horsepower second, rear axle width third, rear wheel/tire ballast fourth.
I've narrowed it down to L2501 (wt 2,601, HP 24.8/19 PTO), LX2610SU (wt 1,786, HP 24.8/19.5 PTO) or L3301 (wt 1,918, HP 30.8/27 PTO or LX3310 (wt 2,778, 33HP/26PTO). Current setup is wt 2,193, PTO 30/25.5 PTO, so the LX's weigh less and the 2501s are less HP than TC30.
Within above group L3301 stands out. Adequate power for mowing. Adequate rear wheel width for stability. Close in dimensions to your current tractor so your existing implements should be (relatively) easy to mount. (L2501 can be somewhat short of power for mowing.)
If you are inclined toward a deLuxe model research Kubota's "Grand L" L3560 model. Highly recommended for those over age 55 years.
T-B-N ARCHIVE:
