Buying TN60A or TT60A...Help??
   / Buying TN60A or TT60A...Help?? #1
Hobbit
Hello to all..:) I've been lurking around here for a few days trying to learn what I need to know before jumping into this. So, take pity on me and don't be too harsh.;)
I'm looking at a TN60A that was out on a lease for 2-3 months. It has 53 hours on it and retains the balance of the factory warranty (I've been told). Price is $16,700. I am comparing it to the TT60A (2 hrs on the meter). Price is $14,500. Both tractors are complete but no extras or implements.
I have a small "farm" that is in a renovation phase. About 15 acres of pasture land that is being reclaimed (overgrown, brushy, briars, etc), and an additional 25 acres recently logged that may be replanted or moved into a different agricultural use. Terrain is level to gently sloping and rolling with a small year round stream that needs to be crossed to get to some of the property.
I have previously owned a JD CUT (850 MFWD), but I believe that I need a larger more robust machine for this work.
Comments please. Prices?? Size of tractor?? Suitability?? If you ask the questions, I'll provide the answers!
Thanks for your help!
   / Buying TN60A or TT60A...Help?? #2
Regarding the TN60A; I presume this to be a 2WD since the price indicates it. Sounds like an awfully good price for a machine with so few hours, but if that's the case go for it.
I have a 2000 TN65 4WD that I used on a 70-acre tillable farm and it meets my needs. You couldn't go wrong on the TN60, but I would look further for one that has 4WD. Again, I'm just assuming the TN60 is a 2wd.
There's been way too many occasions where 4WD was a necessity in mud, hills, pulling a round baler up a hill, etc.
Good luck.
Right you are about the 2WD thing. I have considered FWD and have not completely ruled it out, but the additional cost is an obstacle that I would need to overcome. My JD was a MFWD and it was helpful (mostly because the tractor was underpowered for the tasks at hand).
My use for this tractor will be general maintenance around the farm. Clearing, cutting, fencing, some light ground engagement (tilling, disc harrow, plowing.?), water lines (not sure how I'm going to do that), and managing/maintaining forage crops or newly planted timber stands....etc.
Most of the ground is level to very gently rolling and generally dry. Located in the heart of North Carolina.
I am also looking at adding a backhoe (maybe.??). They're a bit spendy..
Is the '60 enough tractor?? Or should I be looking at '75 or larger? Confusion reigns supreme:confused:
Thanks for all of the help!!
   / Buying TN60A or TT60A...Help?? #4
I looked at both the TN 75 and TN60; decided to go with the TN60 for one reason: TN75 has a turbo; TN60 is normally-aspirated. This equates - in my opinion - longer engine life and less maintenance.
I recall in my flying days the turbo charged engines had a TBO (time before overhaul) of perhaps 1200 hours; where a normally-aspirated engine may be 2000 hours.
Yes...
Thanks for reminding me! I definitely want to stay with the normally aspirated engines. I spent many long hours in the air (military pilot-Instrument UT, Commercial, Instrument, MEL), and know what turbos do to the wear rate of engines.
Does anyone know anything about the TT series of tractors?? I looked at one the other day and they seem to be a lot of tractor for the money. I could get a TT75A for less money than the "used" TN60A. Of course, you sacrifice some of the extras.....???
Also, what about backhoes for these tractors?? Are there any out there that are a "reasonable" price?? And of course won't fall apart. Of course I realize what the laws of economics say.:rolleyes: :eek:
   / Buying TN60A or TT60A...Help?? #6
Scroll thru the last 2 or 3 pages of posts. You will find a few posts that either I started or revived regarding the TC55 and TT60A. I have similar needs and all of the fine folks on this site helped answer my questions...which are very similar to yours. In fact, the posts filled in all the info that is missing on the New Holland literature and web site. If you do not requrie a cab, the TT60A is hard to beat for the money. Any more typing here will simply be a repeat of what has already been posted.
Right....I spent many hours pouring over the latest threads about this size tractor before posting, but could have missed something....I will go back and reread. In any event there seems to be precious little information available about the NEW TTxxA series of tractors. I suspect that is because they are so new that a lot of information hasn't filtered down to the general populace yet.
I have now spent about an hour driving both the TT and the TN at my local dealer. I am going to go back in the next day or so and re-do my own little tests--to see if my first impressions are still accurate. The dealer doesn't seem to mind my "playing" with his tractors (I suspect because he realizes that a sale is imminent..;) ;))
I have also discovered that implements (at least "good" ones) are rather spendy. The price is going up.:rolleyes:
Question still remains---and I hope some of you have the experience/knowledge to answer---Backhoes for this size tractor---What are the better ones?? and Are there any on the market that are "better values"?? That is to say...Are there any less expensive models that are still good performers and will not breakdown every few hours??
Thanks to everyone here for the help....Great site!:)
   / Buying TN60A or TT60A...Help?? #8
airplane motor: gasoline,
tractor motor: diesel!!!!!!!!!!!!!!!
HUGE difference
a diesel really is just a giant air pump, the more air you can pump in, the more fuel you can put in, the more power you get. All those over the road trucks? Turbo's and have been for y ears, they get a million miles or more before rebuilds. All the big 3/4 ton trucks? all turbo-diesels
All you gotta remember is not to work it really hard and then turn it off, otherwise the turbo bearings cook in the hot oil, just let it idle down for a few minutes, which isn't bad advice for any motor.
My lesson learned? (the hard way of course). once you decide on a size of tractor, get the most HP (within reason) you can afford within that size.
i.e. if you have have decided that you want a TN 3 cylinder tractor (since the 4's are actually bigger), go for the TN75 if you can swing it. If you don't need the power, you don't have to use it, but if you do want it and it's not there......
   / Buying TN60A or TT60A...Help?? #9
Got to agree with Brian... A turbo is not a maintenance or life problem on a diesel. The turbo actually improves emissions, reduces noise without the need to a muffler and gives you power when you need it. All good things. My truck (powerstroke) has 240k miles without a single engine issue. I wanted a turbo tractor but I couldn't pass up on the deal on the tractor I got (-$15k for 18 hours use).
TT vs. TN
Both have their market (obviously).
I looked at both a number of years ago. Compare all critical numbers including weight, tire size, lift capacity and hydraulic flow. Number of gears and speeds below 1 mph may be important depending on use. Only you can decide.
Be sure to get at least two rear remotes. You may not use them often, but if you need them they are expensive to add. I have used my remotes for my square baler and operating the county's no-till seeder for planting pasture and hay ground. Also useful for equipment with lift gates or position control.
   / Buying TN60A or TT60A...Help?? #10
Hey Hobbitt-
When test driving, how was the turning radius on the TT 4WD? Did it feel tight enough to handle the usual barn/loader chores, maneuvering around buildings, stalls, etc? When my dealer gets one, I want to compare it to the TC55 or the so called TC60. I'll probably still go with the TT series based on price/value.
   / Buying TN60A or TT60A...Help?? #11
I'm not up on the TT series.. anyone care to elaborate.. however.. even with a few 'guesses ont he TT60 capabilities.. sounds like either of the 2 being evaluated are a steal at the posted price.
Soundguy
A couple of things...I have been back to the dealer twice since the last post. Spent a little more "seat time" trying to get the feel of the two in question. Actually drove a Boomer with FEL as well. I made a lot of comparisons and came away with some definite ideas.
I decided to stay with the TT or TN series mainly because of the size and weight advantage for field use and because I don't really need the more compact abilities of the Boomer. My perception of the TC series machines was a good one, especially if you need the slightly increased maneuverability that their size allows and they seem to be somewhat "lighter on their feet" than the TT or TN. Steering is very responsive and positive and the tractor handles well at low or high speeds.
So Steve, my perception was that the TC series machines might be somewhat better in close quarters. The turning radius of the TN is fine for my use and in fact somewhat better than I thought it would be. For the uses you mention, I would have to rethink my parameters, but I believe the slightly smaller TC series would be a better fit. IMHO.....
I have decided on either the TT60A or the TN60A....the TT75 is a lot bigger and although I could get it for about the same money, I think it is more machine than I need.
So one more trip to the dealer will probably seal the deal one way or the other.:)
   / Buying TN60A or TT60A...Help?? #13
the TN60 and the TN75 are physically exactly the same size.
the only difference is a turbo and a richer fuel profile and thus more hp and torque.
No real other differences.
Sorry Cowboy....if you will reread, my comparison was about the TT75 not the TN.;)
You may very well be correct about the TN75, although I have never seen one or read the specs.
   / Buying TN60A or TT60A...Help?? #15
Hmm.. get a tt75 for near the price of the tn60 or tt60? hmm.. If it's close.. ya might just get it???
Soundguy
Soundguy and others....
Keeping in mind that my tractor experience is not great, I offer the following as my thinking (however faulty it may be...:D )
I can get the TN60A for $16,700. The TT60A would cost about $14,500, and the TT75A about $16,900. Both of the TT's are absolutely NEW (only a few demo drives). The TN60A has 53 hours on it. It has 22 months of the original 24 months factory warranty remaining---so it is ESSENTIALLY new, but has left the dealership for a couple of months. After driving these tractors, I found the TT60A and the TN60A very similar in size, but much different in std. features. The TT75A definitely has more available power than either of the others, but it is equipped exactly like the TT60A.
Sooo......If I want the features that are on the TN series, I would have to buy the TN series. The TT's are really stripped down basic tractors (which isn't necessarily bad). You just need to analyze your needs before making a purchase decision. I like the idea of the extra power the TT75A has available for about the same money, but I also like the features of the TN series (some of which are not available on the TT's at any price).
And so, the quandry..:confused: One more trip to the dealer tomorrow will have to suffice. I have all of the information, just have to make the decision!!
Forgot about this...I am still seeking information about backhoes for these tractors. As previously posted, are there any real values in backhoes?? Any models that hold up well, but are not as expensive?? I really need a backhoe, but don't want to spend a fortune as it will be only intermittently used. I know this is a tough one, but I am hoping someone has some ideas!!
Thanks....
   / Buying TN60A or TT60A...Help?? #18
Hobbit
I faced the same quandry you mention, I looked hard at the TT an TN. In the end I went with the TN 75 for the better ergonomics, flexible link ends, shuttle shift 12x12 transmission, faster hydrualics, etc. I don't regret my decision even though I paid a few more $ as I intend to keep this tractor for a long time. This also reinforced when I help out a local farmer and drive his 5610, 7710, etc which have a more traditional layout similar to the TT. Good luck.
   / Buying TN60A or TT60A...Help?? #19
well yes, i realize that, but the TT and the TN are very similar, you have to do your own comparison. :p I know the TN series, not so much the TT.
Grab teh brouchures and go to work. I wouldn't doubt it's the same motor, and probably the same issue.
   / Buying TN60A or TT60A...Help?? #20
As i said before.. i have no exp with the TT series.. but if they are a 'economy' version.. then it sounds like the continuance of the old XX10 series. The Tn series with more options could be thought of as a xx20 or xx25 series which are comparitively feature 'rich' while the xx10 series is spartan. xx20 has nice flat op platform, deluxe gauges.. multi range trannies, some with shuttles.. etc. The xx10 series was pretty much an engine with sheetmetal and a seat.. bare minimum gauges on the dash and you stradled the tranny. Pretty much you were just buying HP on rubber.. vs the bells, whistles, and chrome plated 'gongs ' on the more feature rich series.
Me personally.. i like the spartan xx10 series.. I actually traded up from a smaller 1920 to a larger 7610s ( mainly to get hp ) but I didn't need or care for the 'chrome' the 1920 had.. and straddling a tranny in order to get 1.25 to 1.5 x more HP for my dollar.. etc. For me, the choice was easy.. I want size and hp per dollar over 'deluxe' features...
Good luck on your choice. the only thing I can say is that if you want to spend 17K.. look at the tt75 and the tn60. decide what makes the deal.. the hp or the features. if you want to spend 15K.. the choice is made.
Lastly.. of the 3.. I don't think you can go wrong....period.. no matter what you choose..
Soundguy
Classic 1969 Massey Ferguson 135, newly rebuilt engine, refurb front end, 3-pt blade.
Classic 1969...
10 X6 MANIFOLD (A58214)
10 X6 MANIFOLD...
Kubota HB84 Hopper Broom (A53317)
Kubota HB84 Hopper...
2019 F-550 Bucket Truck (A61306)
2019 F-550 Bucket...
John Deere 5055E (A53317)
John Deere 5055E...
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
