Oil & Fuel BX-2200 Fuel Gauge Problem
   / BX-2200 Fuel Gauge Problem #1
Anonymous Poster
Epic Contributor
My BX-2200 was delivered last evening before I came home from work and the first thing I noticed, before I started it, was that the fuel gauge did nothing when I turned the ignition switch to ON. I checked to make sure that the dealer had fueled it up ... the tank was fuel. The needle does not move from the lowest position below EMPTY. I know that some of the earlier BX-2200 had problems with the tank float but this appears to be a different problem. My Serial number is above the 59000 mark. I also checked under the dash to see if the gauge was connected and it appears that it is. Has anyone out there experienced the same problem.
   / BX-2200 Fuel Gauge Problem #2
Read the thread below about guage issues. Our new BX2200 with a over 6000 serial has guage problems...although the needle does move....A part is on order for us.
   / BX-2200 Fuel Gauge Problem #3
Geeze Ed, I feel bad that I get so many replies to my problems and you only get one. So here goes.
You are probably just imagining it!
Actually, I have been trying to call you to find out what the dealer said. Is he sending the mechanic out?? Post whats up so that you can be cool like me!!!!
Rogue
Year: 2013 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A56859)
Year: 2013 Make...
1995 Koehring LRT-110 7.5 Ton 4WD Rough Terrain Crane Truck (A55787)
1995 Koehring...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A55302)
2016 Ford F550 4x4...
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
2005 Toyota Highlander SUV (A56859)
2005 Toyota...
