Scooby074
Super Member
My advice is get the deere gauge or build a block gauge.
Tape measures dont work as I found out when I set mine. The deere gauge is the best $8.00 you'll ever spend.
The adjustment on the rear bolts, with the locknuts, should provide all the adjustment to get the deck level you need. The lift pins are inside the oval holes under the adjustment bolts correct? 3pt flow control opened all the way up? 3pt lift arms moving for their full stroke? Blades installed correct?
Try measuring blade height with the deck height knob on 3"
