Tires BX 24- Who actually unloads tires w/BH
   / BX 24- Who actually unloads tires w/BH
Note to self....
After purchasing a quick fill adapter it has dawned upon me that all tire stems are apparently not air / liquid stems. Not sure what those would look like but its pretty clear mine are intended for air only. Seems I will need to look at another adapter to get water in there or different stems.
   / BX 24- Who actually unloads tires w/BH #22
Kevin I don’t know of the different stem you are referring to but in my case the tires I have filled you could fill by removing the existing core and with a $15 valve used for adding liquid to a tire do the job on any tire.
MarkV
   / BX 24- Who actually unloads tires w/BH #23
What hasn't dawned on you is you have to take the valve core out of the valve before you can fill the tire.
   / BX 24- Who actually unloads tires w/BH #24
MarkV said:
1*Kevin I don?t know of the different stem you are referring to .
MarkV
1*There isn't any such thing he just don't realize he has to remove the valve core from the valve before he can fill the tire.
I know the core has to come out but it still does not appear that this quick fill valve will fit. Though I confess, I have never attempted this before. It just does not look like it will work.
I purchased this one ....
"Use this all-brass, no-rust unit to fill tractor tires with water or calcium/water ballast. Design lets air escape automatically so you don't have to stop and vent while filling. Attaches to standard 3/4" hose and air/liquid tire valves only."
http://www.tractorbynet.com/forums/attachment.php?attachmentid=107240&stc=1&d=1217286213
But it looks like I may need this one...
"Permits fast filling of tires with fluid for ballast. Button valve on side releases air displaced by fluid. Hose connection fits 3/4" standard garden hose. Comes with 2 extra bushings for small tems.
"http://www.tractorbynet.com/forums/attachment.php?attachmentid=107241&stc=1&d=1217286213
2006 John Deere 120C Hydraulic Excavator (A56857)
2006 John Deere...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
2015 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2015 DRAGON 130...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
