BX front axle oil leaks
   / BX front axle oil leaks #1
kubby
BX1500
Just wondering if anyone else has had problems with a BX model leaking oil from the front king pin joint. Mine started seeping on one side at 225 hrs. Just had it repaired on warranty but it still leaks. I have heard of a couple of others having this problem. Anyone know if there is a service bulletin on this?
Thanks,
Bill
   / BX front axle oil leaks #2
Some folks have switched to a "gear lube" type oil in the front rather than the realatively thin Super MDT hydraulic oil called out in the book. I would think a good quality synthedic gear lube would be fine in that application, and not be as apt to leak past the O-rings in the knuckle.
BTW: At 85 hours on mine with heavy FEL use, I still have no leaks there. /forums/images/graemlins/confused.gif
   / BX front axle oil leaks #3
Mine too is leaking, haven't got a chance to bring it in yet
Alex
Talked to my dealer today and he said it was a pressure problem caused by lack of a vent in the axle. That could not be it though, at least not the whole problem, because it was seeping when I went to pick it up after the repair. I washed it off and it leaked more without even being run. I heard from an ex-Kubota mechanic that this is a common problem on the BX tractors. Hopefully Kubota will come up with a redesigned seal or something.
Bill
   / BX front axle oil leaks #5
My BX23 front axle leaks in two places - at the pivot point in the middle and on the pivot seal (kingpin?) on the right hand side wheel. It leaks so bad that I have to add fluid into it every few days and it will leave a big puddle on the ground. The tractor is getting hauled up to the dealer tomorrow to get these leaks fixed, plus fix the broken air cleaner mount, the hazards don't work, and get a 300 hour service.
Jim,
I'd be interested in what your dealer has to say, and what they do about your leaks. Also whether their repair is successful. It does seem that this is a common problem with the BX series, so it would be nice to discover the real cause.
-Bill
   / BX front axle oil leaks #8
The tractor is loaded in the trailer and ready to drop off tomorrow morning. I don't expect to find out anything until next week but I will post back when I hear anything.
   / BX front axle oil leaks #9
Jeff....... when posting a link, just a short explanation to go with the link is sufficient.
When you post the long web address in both fields, it skews the rest of the thread so
people have to keep moving the text from right to left and back again to read it. I have
enough trouble trying to read the text when it isn't moving. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
thanks Junkman
Jeff,
Thanks for the link to your thread on venting. I have vented mine and will see what happens. Sop far it seems to be slightly slower but still seeping.
I have to believe though, that the seal design is bad. Pressure may be an aggravating factor, but the transmission gets much motter than the front axle and doesn't seep a bit. Also, my left side leaks but the right side is totally clean. If pressure was the only problem, there would be leakage on both sides. In addition, the leakage comes only from one point on the pivot joint, not all the way around. And why did I not get any leakage at all for the first 200 hrs, all hard usage, then it started to leak? There has to be a design problem here.
-Bill
2014 Walker Compactor (A55787)
2014 Walker...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
UNUSED AGT STSD10 Seeder (A47477)
UNUSED AGT STSD10...
Giyi 72" Box Broom Sweeper (A53316)
Giyi 72" Box Broom...
58" 3pt Snowblower (A50775)
58" 3pt Snowblower...
2017 Ford E-450 LP Handicapped Bus (A55788)
2017 Ford E-450 LP...
