BX - If you've considered mulching blades
   / BX - If you've considered mulching blades #1
lww05
East Texas
BX23
BX - If you\'ve considered mulching blades
Looking to hear opinions on the design and shape of these mulching blades for the RCK60B-22BX.
Re: BX - If you\'ve considered mulching blades
another
another,
next to last
   / BX - If you've considered mulching blades #5
One looks like a mulching blade, but the other just a conventional standard blade.
The mulching blade looks to have some 'high' cutters to chop up cut grass as they rotate. Not sure how effective either are for mulching, but likely there are some test results somewhere.
This area of the blade and the amount of angle there that I assume would create a downdraft, in my opinion outweighs the amount of lift on the tip of the blade.
Ideas?
To correct my first post where I said these mulching blades, I meant to say comparing the mulching blade against the standard blade.
   / BX - If you've considered mulching blades #8
I understand there is a need for the downdraft along with the lift to stir up the clippings and mulch them up finer before letting them 'escape', in hopes that the clippings are as small as possible. That appears it would be accomplished by the mulching blade, IMO.
Do you know how they work as mulching blades?
   / BX - If you've considered mulching blades #9
Thanks for the pics! I had already ordered the kit last week, but its still neat to see it ahead of time.
How do the baffles work into the equation? From the other posts i've read, it sounds like a decent setup (if you dont overwork it).
The std blades do a great job, but there isnt any lingering! Cut and GONE into a fan of hay... Hopefully the mulch kit will help out some.
I should have continued this thread at the end of this one:
Shortened Very Long URL
IndyChris,
The mulching setup for the 60" deck does well at grinding the clippings up, you should be satisfied on this part. On my particular lawn of half St Augustine and half Bermuda, it does not leave as smooth of a finish cut as what the standard blades did. The 54" mulching deck I used to have did a better job. Although it is not total crap, I am disappointed with the final cut now on the 60" deck. Maybe you will have better results than I have had.
Anybody have a good close-up pic of some Gator blades even for a different make tractor? I'm interested in seeing the amount of area for the downdraft versus the amount of lift to compare against this sucky Kubota mulching blade.
MikePA: Cleaned up long URL. Please review your message before posting it. It's simple not to do this. Just insert a descriptive word or two between the {url=http://whatever}<font color="red">Enter words here</font>{/url} instead of the entire URL. Replace parentheses {} with square brackets in previous example.
2015 Chevorlet Silverado LT Z71 (A50120)
2015 Chevorlet...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
John Deere 4045D (A50121)
John Deere 4045D...
