BX won't pull a hill-PROBLEM SOLVED!
   / BX won't pull a hill-PROBLEM SOLVED!
Did you have the valve stems at 12 o'clock and push just a little air from the hose thru them and then depress the valve stem to see if air comes out or "goo"? If rimguard still comes out, then I would think that the tires might be a little overfilled with Rimguard.
James K0UA
Thats exactly what I did, and goo still came out. They were overfilled by a little bit I think or the rimguard was pooling over the valve stems.
   / BX won't pull a hill-PROBLEM SOLVED! #32
You should also have it jacked up with all the weight off the tire when checking the rimguard.
   / BX won't pull a hill-PROBLEM SOLVED! #33
just put the valves at 1200 purge a little air to clean out the valves and check .
Problem with tubes if you get a nail in the tire ,you just cant plug it,gotta take it all apart and patch.Ihave several plugs in mine over the years
Same way with my atvs,by installing a tube,there is no quick fix out in the woods,unless you rely on fix a flat which imho doesnt work.
ALAN
   / BX won't pull a hill-PROBLEM SOLVED! #34
Might want to post the solution in the other thread -- or link both ends. I can see somebody, years from now, scratching their head.
larry
   / BX won't pull a hill-PROBLEM SOLVED! #35
larry
This was a good one wasn't it? Who would have thunk it? "I have no rear wheel drive sometimes" Because my rims are spinning inside my tires... geez, had me going for a while.!
James K0UA
   / BX won't pull a hill-PROBLEM SOLVED! #36
Well I will admit I never thought about the rim slipping inside the tire. But will definitely keep that in my thoughts in the future.
Glad you figured it out.
   / BX won't pull a hill-PROBLEM SOLVED! #37
I had forgotten my BX23 occasionally did the same thing. I remember being horrified at the time. Apparently I suppressed that memory pretty well until now!
Zero Turn Mower (A55853)
Zero Turn Mower...
John Deere 4600 (A53317)
John Deere 4600...
2019 John Deere 5090EL (A53317)
2019 John Deere...
2012 BMW 328i Sedan (A55758)
2012 BMW 328i...
2000 Ford F-250 Pickup Truck (A55852)
2000 Ford F-250...
2016 Isuzu NRR 20ft Curtain Side Box Truck (A55852)
2016 Isuzu NRR...
