BX1500 first repair to be made to the deck.
   / BX1500 first repair to be made to the deck. #1
dex3361
Elite Member
N. of Charleston WV
Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
I was about half way through mowing and I heard a noise a sound and felt a vibration. I stopped and did a once over and found a spindle nut loose and the bearings were shot. I put in and order for bearings and seals so I guess it is time to do my first BX1500 repair. The tractor is a 2005 model and I think this is the original belt. Doesn't look to bad but since I will have it down to that point I will replace the $75 belt.
   / BX1500 first repair to be made to the deck. #2
How many hours do you have on your 1500? I am at 900 on my 2003 BX2200 and still using the original belt and spindles.
I used to slack the belt when I stored the deck over the winter, but I stopped doing that 5 years ago or so.
I have about 270 hours on it. It was formerly owned by JohnnThomas(TBN member). It only had 100 hours on it when I got it. I am going to rebuild both outside spindles as the right side seems a little rough. That way hopefully I will not have to fool with it for a while.
   / BX1500 first repair to be made to the deck. #4
Feel certain that is the original belt. Great mowing machine that I only changed oil and filters.
I am amazed at how well the little 2 cylinder diesel runs. I will have it back up and running next week after the parts come in. I used the new Kubota parts diagram and uploaded it to Messicks web site. It was a smooth process. It is a good tool for Kubota owners.
The Deck epair is all complete. While I was at it I changed the deck gear box oil. I was going to change the belt but thought I would run it a few more years. I also changed the primary fuel filter since the deck was off. Put it back together with freshly sharpened blades and mowed for about 4 hours. I was amazed at how much quieter it was. I guess it sneaked up on you:laughing:
2202 (A51691)
2202 (A51691)
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
Wolverine Quick Attach Manure Bucket (A50515)
Wolverine Quick...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Kubota BX2230D (A47384)
Kubota BX2230D...
