Well, I used to have a JD LT155 lawn tractor that had a 14" turning radiius, so it was a little bit of an adjustment. The power steering is so nice, I don't even pay attention to what the turning radius is, just make big loops with one finger on the wheel. I actually like to make long straight lines when I mow so I usually make a 3-point turn on each end, pretty much the same I did with the little JD. It is so fast and effortless, I never really thought about wanting it to turn sharper.
Unless you can't fit it in certain spaces, i would lean towards the 60"MMM. I also thought I would get the 54", but am glad I got the 60". It is a heavier guage, and has a better suspension pivot system that the 54" doesn't. Also cuts the mowing time.
On a personal note, no matter what anybody tells me, I do not like the way a 2-cylinder diesel runs or sounds. there is nothing wrong with it at all, I just like the purr of the 3-cylinder better, I like the way it starts and idles better. Of course the
Bx1500 just a little bit above idle smooths out probably better than the 2230, but I simply prefer the 3 cylinder in everyway.
I liked the smaller tires and lower stance of the 1500, but after all the snow we have gotten, I am glad for the little extra clearance of the 2230.
The first time you take a full bite of heavy wet sand or clay and can't lift the bucket, you will be glad you at least had the extra power over the 1500.
By the way, I got an extra set of Bar tires loaded for $265. I prefer them over the turfs all year except in the wet spring. If I was only going to have one set of tires it would be the bars. I have both sets of rears loaded with rim guard for ballast. rears loaded plus me (250 lbs) plus rear blade (175 lbs) equals no problems with the loader.
[/image]
