Leejohn
Elite Member
If you trade it in I might be interested in it. I'm not to far from you. What year is it?
To make that engine right, with the amount of heat it generated..........about the only thing salvageable is the block. Maybe the crankshaft if you can get it turned and get oversized bearings.
Actually, when an engine gets too hot, clearances shrink. Here's the problem with that. When you've got a piston that's the same size as the cylinder instead of a few thousands smaller, you get wear. "Rings" don't really get shot. What happens is that the cylinders usually get out of round making it so that the rings can't seal correctly.
I don't want to say "toss parts at it" though. Run a compression test on the engine. It should be as simple as turning the engine over with the starter (fuel shut off) with a compression tester in the glow plug hole. You'll spend some time with this, but that will give you a good idea as to the overall condition of the cylinders. Once you have tested it, put a few squirts of oil in each cylinder. If the compression comes up dramatically, there is a ring sealing issue. Keep us posted!!!
I wouldn't take that engine if it was given to me. It will turn in to a money pitI dissagree. I'm sure the camshaft, connecting rods, timing components, & most of the valvetrain are also salvageable. Also, when a crankshaft is turned, the journals are machined smaller, so you would use undersize bearings to maintain the correct oil clearances.
If you're not loosing coolant at this time, I wouldn't expect more than a standard rebuild to be necessary.
1802cool
What is non-interference combustion chamber, never heard of that before..
When an engine gets that hot the rings loose all the tension. If the rings don't have tension they are shot.
To the OP how did it ever get that hot with out noticing smoke or steem or smells.
Bill
I'll bet that pit will be nowhere near as deep as the amount that they will deduct from the tractor on a trade-in. That's assuming they don't hide some of it in the new tractor.
