BX1800 Loader - burst a hydraulic hose
   / BX1800 Loader - burst a hydraulic hose #11
Mike.
It’s not necessarily bad… but you will find the weak spots in the system. On the other hand, when you have a failure it is always very evident and fairly easy to repair, (but rather oily). There is no easy way to avoid this other than ‘trying’ to use the curl circuit while engaging things that are reluctant to move, this way you have a relief and the movement of the piston in the cylinder can go opposite to the direction you are expecting as your tractor pushes things. Only real fix is a bigger tractor/loader. And even then it can happen…
I have never broke anything on Kubota hydraulics but I have on MF and IH…KennyV.
   / BX1800 Loader - burst a hydraulic hose #12
Mike.
2014 Walker Compactor (A55787)
2014 Walker...
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
Butterfly Artwork (A55758)
Butterfly Artwork...
AUTO REWIND 12V HOSE REEL (A54757)
AUTO REWIND 12V...
(3) ROLLS OF 4' GALVANIZED FIELD FENCE (A54757)
(3) ROLLS OF 4'...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
