BX1800 Loader - burst a hydraulic hose
   / BX1800 Loader - burst a hydraulic hose #11
Mike.
It’s not necessarily bad… but you will find the weak spots in the system. On the other hand, when you have a failure it is always very evident and fairly easy to repair, (but rather oily). There is no easy way to avoid this other than ‘trying’ to use the curl circuit while engaging things that are reluctant to move, this way you have a relief and the movement of the piston in the cylinder can go opposite to the direction you are expecting as your tractor pushes things. Only real fix is a bigger tractor/loader. And even then it can happen…
I have never broke anything on Kubota hydraulics but I have on MF and IH…KennyV.
   / BX1800 Loader - burst a hydraulic hose #12
Mike.
2002 Western Star Trucks 4900 SA Truck (A51692)
2002 Western Star...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
Generac Generator (A51691)
Generac Generator...
Year: 2012 Make: Honda Model: Pilot Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A51694)
Year: 2012 Make...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
