BX22 air filter bracket broken again
   / BX22 air filter bracket broken again #11
This I GOTTA see. Anybody got a photo of the newest BX bracket??
Here ya go. Pictures of the bracket that I had replaced that broke. The gold part on thr outside broke off close to the gray mounting point. letting the air filter assembly rattle around.
   / BX22 air filter bracket broken again #12
Thanks Tim! :D
IMO that is a much better bracket design than the older BX's. Looks beefy and doesn't have tension on it.
If that works, I bet bungee cords would be just fine on the older machines. I am on my 3rd BX23 (strap-style) bracket.
   / BX22 air filter bracket broken again #13
I was only going by the comment that the dealer made to me that it appears to be the BX2200 problem all over again. the bracket broke before the first oil clange was needed.
   / BX22 air filter bracket broken again #14
I broke mine several times before i modifyed it,and its held ever since.The problem is half the aircleaner is hooked solid to the tractor[intake] and the other is on a vibrating motor-stupid design.
If you look at my pic ,i welded up a simple iron assembly.One end hooks to a front bolt that holds the cowling on,the other end ,to the rear bolt that holds it on .The airfilter,is bolted solid to it ,so its not attached to the engine.You can whip up this easily in an hour,with no drilling or nothing on the tractor.Problem will be solved forever.
ALAN
   / BX22 air filter bracket broken again #15
Well here we go again. Just Broke when I started it this evening and that makes two times in less than a year.
Pic. of Broken air cleaner bracket on my BX2660-Round 2!
   / BX22 air filter bracket broken again #16
[:eatcrow:]
Wow, they actually blew it again. Bungee cord time.
   / BX22 air filter bracket broken again #17
The new BX air filter brackets are much stronger,I have replaced several on BX tractors and have not had any complaints and don't think they are that expensive.
   / BX22 air filter bracket broken again #18
Cost isn't an issue. This is the laterst model, new tractor and still under warranty. Just would prefer to have things work properly and not have to perform quality control and actually use warranty for repairs. I hope that the next time is the charm......
   / BX22 air filter bracket broken again #19
I just replaced one for a friend and the bracket was a new and improved model. The mount that bolts on to the engine is thicker and the strap is different.
   / BX22 air filter bracket broken again #20
I am on my second one for my BX23, but mine is a 2004 model, Is it still happening on the brandy new ones?
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
More info coming soon! (A56859)
More info coming...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
