I am new to this forum and have very limited knowledge of the inner workings of tractors/cars but I thought I'd throw out my situation.
My BX22 is three years old with 250 hours. I was working on making a golf green when my tractor immediately shut down without any sputtering or other symptoms. If I tried to restart by turning the key to the right, the engine starts but then cuts off when the key springs back to the run position. If I tried holding the key in the start position the engine stays running but if I try to move the gear out of neutral, engine shuts down.
With the help of a neighbor, he found the solenoid fuse had blown. We put in a 15amp fuse, it blew. Put in a 20amp fuse (ran out of 15s) and everything was fine for three days. Yesterday, same thing happens again. Replaced fuses blow soon as ignition key is turned. Initially we did a visual check to locate any possible shorts.
Tractor repair guy is coming out today b/c I have a tight time frame and need the BX badly.
Any suggestions or information so I don't get taken to the cleaners with a huge repair bill?
Dave - Manassas, VA
Dave - Manassas, VA
