BX22 Creeping froward. Need help to solve.
   / BX22 Creeping froward. Need help to solve.
There should be a centering adjustment. As things have worn your adjustment has gone out of spec and needs to be tweeked.
I been thinking that the neutral holder link is what controls this, but not sure exactly how to adjust it. I was/am hopping for some confirmation of this is whats causing my creeping before I try to adjust it. I really don't what to make another issue and really mess something up big time.
   / BX22 Creeping froward. Need help to solve. #12
I am no hydro expert but are the pedals adjusted properly? They are may need some adjustment with that many hours on the clock. My neighbors cub cadet had a creep and it was out of adjustment. I think some hydros have neutral valves.
The BX22 is a single Fwd/Rev petal and as said before everything with the petal itself functions just fine and its link to the HST are ok too. I looks to be the neutral holder (or as what you called the neutral valves) is what needs to be out of adjustment.
FIXED!!! Re: BX22 Creeping froward. Need help to solve.
Problem is fixed! and it could not have been easier to fix.
In the photo attached you will see a 1/2" bolt in a curved slot. Jack up your tractor so both rear wheels are off the ground. I put some blocks to support the tractor from moving. Loosened the bolt, start the tractor, I slowly moved the bolt forward and got to a spot where the wheels no longer creep!!
Anyone with this issue should check this out! Message me if you need more info.
   / BX22 Creeping froward. Need help to solve. #15
Re: FIXED!!! Re: BX22 Creeping froward. Need help to solve.
:drink:Thanks for the update!! Awesome!:cool2:
   / BX22 Creeping froward. Need help to solve. #16
I agree.:thumbsup: Beats that enquiry that is never reported back on when resolved.
2015 Jeep Cherokee Latitude SUV (A50324)
2015 Jeep Cherokee...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
28013 (A50322)
28013 (A50322)
1998 FORD CRANE (A52472)
1998 FORD CRANE...
2020 Chevrolet Tahoe SUV (A50324)
2020 Chevrolet...
