cpicton1
Go for the bars. They have a wide foot print and the bars are designed to get good traction in soft ground. They are not as an aggressive tire as larger type tractor tires. Unless you mow when the yard is wet you shouldn't have any problems. The front tires will do some damage if for some reason you have to mow in four wheel drive. If you have a manicured lawn like a golf course then you might be better off with the turfs for mowing. For my use I can't justify having two sets of tires to change back and forth. The bars are the only do everything tire for me. They also make your BX look great. /forums/images/graemlins/smile.gif
