Kelvin
Platinum Member
- Joined
- Apr 15, 2000
- Messages
- 798
- Location
- East Tennessee
- Tractor
- B2910 & BX23 (previously B2150 & B7100D)
To all,
At times I consider upgrading my older gear drive B7100 to a BX22 or BX2200, with finish mowing being the primary task. I have a B2150 HSD with FEL for larger tasks. A Kubota brand backhoe for my B2150 is more than $7000, while for less than $7000 you can add a backhoe and FEL to the BX (ie, upgrade from a BX2200 to a BX22). Granted, the backhoe will be useful when I start building my house and/or garage, but after that the usefulness will be unknown and rental equipment may be more cost effective.
Questions:
(1) Does anyone have a mid-mower on the BX22, and if so, do you know how its performance compares with the BX2200? I would assume it to be nearly identical, but some things are better on the BX2200 than the BX22 (such as FEL performance).
(2) 3-point Lift Rate: Is it my imagination, or is the lift rate really slow on the BX's? I have two friends who have taken advantage of the ongoing 0% financing deal and recently purchased new BX2200s. I am surprised at how slowly the 3-point lift raises the mid-mower, relative to the 3-point lift speed of my older B7100 and B2150.
Notes:
(1) I hear that Kubota no longer offers the BX22 without the backhoe. I understand that you used to be able order the BX22 equipped like the BX2200 such that you could add the backhoe / FEL later, but no longer.
(2) I tried to connect my small Kubota brand rotor-tiller to my friend's BX2200. The tiller is the one I use on my B7100. The tiller barely was able to connect to the BX's 3-point lift arms, and then it would only raise about 2 inches off the ground. A shorter top-link would've helped. The drive shaft wouldn't connect at all because it was too long, and would've required cutting about 3 inches off in order to work properly.
Thanks,
Kelvin
Questions:
Notes:
Thanks,
Kelvin
