tractor_newbee
I will soon be purchasing my first tractor. I believe I have narrowed it down to a Kubota (but i did find a great deal on a used NH TC33D so that is still in the running), but I have received conflicting opinions from the dealers I have visited and from friends as to what size I need.
The tractor will primarily be used on my 5 ac. I will finish mow about 1.5 to 2 ac. have a fairly large garden, and bush-hog the remainder. I will be doing some landscaping and land development projects over the next few years (maybe a fence, etc.). I know I want a FEL, to be able to run a good tiller, the power to tow a box scraper, and the ability to run a post hole digger.
After the initial bush-hogging and land development the tractor will be used mostly for finish mowing and tilling the garden as needed.
I agree with most posts I've read about not going too small, but I also don't want to go too big, since a large part of the time I will be just mowing grass.
I was told the BX2200 3PH is too low to the ground to run a standard post hole digger, and the field I will need to bush-hogg currently has not been touched in about 5 years so it is quite thick and rough underneath and I'm concerned about not having enough power to bush-hog and/or smooth out the ground. It seems that the bigger size of B7500 might handle the roughness a little better.
Thats the background info, here are my questions:
Which is a better machine for finish mowing? (BTW...I have another post in Atachments about MMM vs. RMM and I'm not sure yet which way I will go so let me know what you think.)
Does the BX2200 have enough power to bush-hogg thick, tall orchard grass? How about the B7500?
I guess I'm leaning towards the B7500, but will this be overkill after the land is under control?
One dealer has told me that I should go even bigger. Any comments?
Thanks for the help!!
