BX2200 Front axle oil
   / BX2200 Front axle oil #1
bulky
just bought one last week and really love it. I was looking at the owners manual and read that when you replace the front axle oil you use Kubota Super UDT fluid or Sae 80 or Sae 90 gear oil. Looks like mine has the udt fluid in it. My question is udt fluid is very thin and gear oil is very thick do you think its a misprint.
   / BX2200 Front axle oil #2
bulky, this has been discussed at great length on the forum in the past two years. I don't guess it's a misprint, since the manuals for other models say the same thing, but it certainly is surprising when you consider the difference in the two oils. Since they all apparently come with UDT in them, I've decided to stay with that.
Bird
   / BX2200 Front axle oil #3
What the heck does UDT stand for? It is an acronym isn't it?
Winnipeg, Manitoba
2001 BX2200 (23 hrs) All Kubota FEL,Tiller, box blade, blower w/elec shute, 60 mid mt deck, Ag tires.
Grey market B7000 w/Tiller (120 hrs)
   / BX2200 Front axle oil #4
<font color=blue>What the heck does UDT stand for? It is an acronym isn't it?</font color=blue>
I think so, but exactly what is a secret known only to Kubota./w3tcompact/icons/wink.gif I think it has sumpin' to do with Universal Tractor Hydraulic fluid.
Bird
   / BX2200 Front axle oil #5
Just gone through the same thing with my B7001 grey. B7100 manual says SAE 80 but Shell Aust site says an SAE 40 Agri oil. Probably does not make much difference as the gears are not spinning very fast or under much pressure not like the hypoid gears in an automobile. Only use 4WD when you really need it. A little bit like having a second diff lock. As long as there is adequate oil in the diff and front end it should be OK.
   / BX2200 Front axle oil #6
Gear oil viscosity is based on a different scale than motor and hydraulic oils. SAE 80-90 is about 30-40 motor oil.
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
2001 KINCAID PRO-SERIES 1200V2 HYDRO SEEDER (A51406)
2001 KINCAID...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A52472)
2006 V.E...
2016 PETERBILT 579 (A52472)
2016 PETERBILT 579...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2022 INTERNATIONAL MV607 (A52472)
2022 INTERNATIONAL...
