BX2200 Hissing noise
   / BX2200 Hissing noise #11
Keep in mind guys that the procedure JRLCHINA is talking about is adjustment of the 3pt return. If your 3pt lever returns to neutral on its own after you raise something, then your adjustment is working. There is a distinct difference in the sound caused by the relief working, it's much louder and harsher than the hissing noise I was referring to. If, however, your 3pt does not return to N on its own, then you do need to perform this adjustment....
I tried that because it is shown in the owners manual that came with the machine. The only other thing to try is to make sure that none of the linkage is not hanging. If that is not happening then I think it is time to call the Dealer.
3PT PTO POST HOLE DIGGER (A52708)
3PT PTO POST HOLE...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A55973)
2017 Gravely...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
IRGC80 Lifted Electric Golf Cart **Unassembled**(New/Unused) Plugs into standard 110 outlet , Com... (A59225)
IRGC80 Lifted...
(2) POLY ROLLING CARTS & CONTENTS (A58374)
(2) POLY ROLLING...
2023 Kubota Z252KH-54 Zero Turn Mower (A56436)
2023 Kubota...
