BX2200 Hissing noise
   / BX2200 Hissing noise #11
Keep in mind guys that the procedure JRLCHINA is talking about is adjustment of the 3pt return. If your 3pt lever returns to neutral on its own after you raise something, then your adjustment is working. There is a distinct difference in the sound caused by the relief working, it's much louder and harsher than the hissing noise I was referring to. If, however, your 3pt does not return to N on its own, then you do need to perform this adjustment....
I tried that because it is shown in the owners manual that came with the machine. The only other thing to try is to make sure that none of the linkage is not hanging. If that is not happening then I think it is time to call the Dealer.
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
2015 CAT D5K2 LGP (A55272)
2015 CAT D5K2 LGP...
INDUSTRIAL PARTS WASHER W/ CONTROL PANEL (A52708)
INDUSTRIAL PARTS...
2020 Tiger Turf Mower, Model 3TT11-61V-37BV-EF1, S/N R1000298, Asset# 60 (DOES NOT RUN - NEEDS (A59076)
2020 Tiger Turf...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
LOT OF TIN (A58374)
LOT OF TIN (A58374)
