JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 4,000
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
Well, for sure it is unrelated to the front axle! The front axle is pivoted in the middle and can tilt either way freely so there is no such thing as it causing "leaning." If it leans it therefore has to be rear axle or tire related. Like PeterK, I wonder if the cab mount is slightly off rather than the whole chassis leaning. Wheel bearings ? No, I can't see that having any effect at all. Tires? If in fact your whole chassis leans then tires is the first place to look. I know you said they are proper size and all that. HOWEVER, I have bought front tires for my BX2200 which had identical markings, types, numbers and designations. The originals were "flat" when viewed looking across the tread while the replacement was instead rounded or "humped." If that same oddball difference existed with rear tires it would probably give you some tilt or leaning. Did you buy it new or used ? Has the sheet metal ever been pulled off for repairs, etc. ? Like Grandad4 I would think the metal bolts onto the frame as does the rear axle without "slotted holes" so that must not be the cause.
