BX2200 lift capacity
   / BX2200 lift capacity #1
Anonymous Poster
Epic Contributor
How much weight have Some of You Fellas had on the 3ph of Your 2200's?
I haven't used that much on mine and wondered just how much had been used on one.
I had about 700 pounds on my carry all a few weeks ago hauling drywall. I stacked the drywall on edge to keep the weight close to the tractor. Drywall is about 60 pounds per sheet and I suspect the carry all weighs about 100 pounds.
John
   / BX2200 lift capacity #3
tomnky,
I've had 20 bags of compost, nominally 40lb each, on my carry all. The load was spread out on a pallet about 3' behind the lift point. All told, should have weighed 850-900lb (I had 9 bags in the loader for counterweight). This is way over the spec, which I believe is 640lb at 2ft behind lift point. I didn't have to move it far (300').
Kevin
   / BX2200 lift capacity #4
when loading I would have the 3pt on the ground. If it won't pick the load - Loading with the 3pt up and putting weight in the loader is a lot to ask of the few bolts that hold the tranny together.
   / BX2200 lift capacity #5
I guess I should have said that I loaded the carryall while it was on the ground, then raised it. As you said, I figured if it could lift it up, it could probably carry it, at least on smooth, flat road with no bumps.
Kevin
   / BX2200 lift capacity #6
I've never loaded up the 3pt, but I did lift over 700 pounds in the FEL from the ground to full height without any problems. I had the back weighted down, of course. Didn't seem to even struggle with it....
Scott,
Thanks again.sounds like the "toy" is a lot more machine than advertised!!!!!!!
Glad I have one.lol
   / BX2200 lift capacity #8
you might want to check, yours probably has them too
I hear that Hurshel!!!!!!!!!!!!
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2006 Husqvarna YTH2148B Riding Mower (A51694)
2006 Husqvarna...
2015 TEXAS PRIDE  GOOSENECK (A52472)
2015 TEXAS PRIDE...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
