BX2200 lift capacity
   / BX2200 lift capacity #1
Anonymous Poster
Epic Contributor
How much weight have Some of You Fellas had on the 3ph of Your 2200's?
I haven't used that much on mine and wondered just how much had been used on one.
I had about 700 pounds on my carry all a few weeks ago hauling drywall. I stacked the drywall on edge to keep the weight close to the tractor. Drywall is about 60 pounds per sheet and I suspect the carry all weighs about 100 pounds.
John
   / BX2200 lift capacity #3
tomnky,
I've had 20 bags of compost, nominally 40lb each, on my carry all. The load was spread out on a pallet about 3' behind the lift point. All told, should have weighed 850-900lb (I had 9 bags in the loader for counterweight). This is way over the spec, which I believe is 640lb at 2ft behind lift point. I didn't have to move it far (300').
Kevin
   / BX2200 lift capacity #4
when loading I would have the 3pt on the ground. If it won't pick the load - Loading with the 3pt up and putting weight in the loader is a lot to ask of the few bolts that hold the tranny together.
   / BX2200 lift capacity #5
I guess I should have said that I loaded the carryall while it was on the ground, then raised it. As you said, I figured if it could lift it up, it could probably carry it, at least on smooth, flat road with no bumps.
Kevin
   / BX2200 lift capacity #6
I've never loaded up the 3pt, but I did lift over 700 pounds in the FEL from the ground to full height without any problems. I had the back weighted down, of course. Didn't seem to even struggle with it....
Scott,
Thanks again.sounds like the "toy" is a lot more machine than advertised!!!!!!!
Glad I have one.lol
   / BX2200 lift capacity #8
you might want to check, yours probably has them too
I hear that Hurshel!!!!!!!!!!!!
NEW  Ripper Shank (A53002)
NEW Ripper Shank...
2015 Crane Carrier Co. Low Entry T/A New Way Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
2008 KENWORTH T800 TRI-AXLE (A52472)
2008 KENWORTH T800...
2015 Caterpillar 410L 4x4 Extendahoe Backhoe Loader (A51691)
2015 Caterpillar...
2015 JLG 449 12ft Drop Deck Equipment Trailer (A51694)
2015 JLG 449 12ft...
