Mowing BX2200 Mower Deck Trouble
   / BX2200 Mower Deck Trouble
Final Report: The MMM deck height adjustment and rate of lowering knobs were both stuck (we knew going in.) The shop found that the cam for height position was jammed and could not be operated without loosening up all attached to it. They took off the deck, ran the whole tractor up in the air where they could get up under and reach the cam area, used plenty of PT Blaster and pryed it loose and back in position. With lubrication both the rate knob and the height knob were loosened and work fine now. Surprisingly none of the deck linkage was bent or out of place and there was really no significant problem. Cost 1.6 hr labor and added some hydraulic fluid. All is well.
Being able to get it up in the air to work under it they were able to avoid pulling any sheet metal or foot rest platform, etc. off as diesel85 (and I both) expected would have to be done.
   / BX2200 Mower Deck Trouble #12
That's great news. Glad there wasn't any damage or bent parts.
When I bought my BX2230, the height adjuster was seized up on it too. With some WD40 and some grunting while turning the knob, I got it freed up. A little preventative lubrication every few months keeps it freed up now.
   / BX2200 Mower Deck Trouble #13
Good deal! Glad it's fixed!
   / BX2200 Mower Deck Trouble #14
The angle iron that holds the height control on my BX2230 was broken right off the frame when I bought it. I did all that diesel suggested. Had my neighbor weld it back on to the frame. It all works fine now except Top. Won't ever catch that top cam. I've been putting up with that for 8 years now. Keep thinking I should operate and see what is amiss. Congratulations on an "easy" fix. I wish mine was. :laughing:
JCT 72" Skid Steer Rotary Brush Cutter Attachment, Asset# 68 (A59076)
JCT 72" Skid Steer...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
UNUSED FUTURE MINI 29" PALLET FORKS (A58376)
UNUSED FUTURE MINI...
2014 Ford F-150 Pickup Truck (A56858)
2014 Ford F-150...
WINCH CABLE DRUM (A58214)
WINCH CABLE DRUM...
2019 KENWORTH T800 HOTOILER (A58214)
2019 KENWORTH T800...
