BX2200 Thermostat
   / BX2200 Thermostat #1
terpdog
Marriottsville, Maryland
Kubota BX 2200
I'm getting no reading from the thermostat of the BX2200. I did just replace the Stop Solenoid. I don't see anything that I missed putting back(everything seems to work fine).
Didn't want to go get another thermostat if it's just a wire that I missed but I don't see anything and all the fuses seem fine.
   / BX2200 Thermostat #2
Replacing your thermostat won't give you a reading. The thermostat helps control the temperature of water circulating in the engine but it doesn't indicate anything. You probably mean you're not getting an indication from your temperature gauge. You could have knocked a wire loose from the sending unit while working under the hood. You can start by retracing your path to the stop solenoid and see if you pulled something loose.
   / BX2200 Thermostat #3
+1.................
   / BX2200 Thermostat
Yes, I just had to be more patient tracing the wires. One wire that was near the front, by the stop solenoid was it. Of course I didn't find this until I pulled quite a few things off.... because.. of course I put those back on. :)
2016 Ford F-250 Knapheide Service Truck (A44571)
2016 Ford F-250...
2025 AllMetal K1912 UNUSED Livestock Metal Shed (A47484)
2025 AllMetal...
2025 Wolverine TL-12-72W Hydraulic Rotary Tiller (A47484)
2025 Wolverine...
2025 AllMetal...
2013 UTILITY 53X102 DRY VAN TRAILER (A43005)
2013 UTILITY...
Hyper Tough H2510 Weed eater (A47484)
Hyper Tough H2510...
