BX2230 can't pull
   / BX2230 can't pull #11
Re: BX2230 can\'t pull
Try wrapping a chain around it and fastening the end to the drawbar on your 3PT hitch. Then lift the hitch up, putting significant amount of weight on the hitch, and drag it away. This is how I move very large rocks.
   / BX2230 can't pull #12
As Jerry and others have said this may be expecting too much. That concrete likely is much heavier than you think and too much for a BX too drag.. I had to have a new set of 3 concrete steps poured for my back house door as the prior set was not done right. The concrete guy doing the work commented that his large kioti backhoe FEL tractor may have trouble removing the old concrete steps to the back of our tree line. Theses conrete block of steps looked about the same as your concrete chunk. When I have time I plan on breaking it up with a sledge hammer ans slowly disposing of it.
UNUSED DIGGIT HEAVY DUTY 20'X20' ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
2013 Ford F-150 Ext. Cab Pickup Truck (A55788)
2013 Ford F-150...
2008 Ford E-350 Altec AT200AV 30ft Bucket Van (A55788)
2008 Ford E-350...
2008 New Holland L175 (A47477)
2008 New Holland...
2022 Polaris Ranger 4x4 Utility Cart (A54811)
2022 Polaris...
2004 Workhorse W22 Motorhome (A53424)
2004 Workhorse W22...
