bx23 or jd4200 loader and backhoe
   / bx23 or jd4200 loader and backhoe #11
Half the weight, half the loader capacity, half the 3pt lift capacity, half the rear tire size, half the hydraulic flow.... probably half the year adjusted new price too. So its half the tractor. Approximately.
But sure, a BX23 is a fantastic little machine if thats what your needs call for. I'd rather have the Deere 2210 in that size but that is also half the tractor.
Honestly, not worth arguing about..As I said: All in what you need it for. I could have bought a B series for less money than mine went for at the time, but it didn't serve my needs. The B (don't remember the series) that they had was considerably bigger than my BX and was probably similar to the 4200.
I have no buyers remorse after six years and would buy the BX23 again.
   / bx23 or jd4200 loader and backhoe #12
Which would you reccomend? They are basically the same hp and specs. different color.
The jd is much larger than the Kubota.
What does sub cut mean?
Cut means compact utility tractor .
Sub cut means sub compact utility tractor. :)
   / bx23 or jd4200 loader and backhoe #13
Let not argue about it, lets settle it definitively...
Code:
HST Tractor	4200   		BX23
HP			26.3 hp		22
PTO HP		20.0 hp		16.7
Torque		57.9 lb-ft		?
Fuel Tank		10 g			5.5
Drawbar Weight	1102 lb		?
3pt Lift		1700 lb		680
Pump	Output	12.4 gpm		5.5
Weight		2875 lb		1520
Loader Lift		1003 lb		460
Loader Breakout	2141 lb		845
I'd call that half the tractor. It would take twice as long to accomplish most tasks with a BX23 vs a 4200, particularly those involving the loader and hydraulics (and thus the backhoe too).
And again, there is nothing wrong with a BX23, but to say its as much tractor as a 4200 is being disingenuous.
   / bx23 or jd4200 loader and backhoe #14
Cheno, just on the off chance that an argument about why "this tractor is twice as much tractor as that tractor", may not help you very much, may I make the following suggestions?
First, making a judgement about which one is better for you depends mostly on what you plan to be doing with it, the condition of the units - after all they are used tractors, and what they are selling for.
The 4200 is a larger framed unit that would be ideal in working on a 2-10 acre rural property with mowing, groundskeeping, road maintenance and light ag chores, to name a few. It could also serve as a small chore tractor for farm use, I suppose.
The 23 is about the smallest rig you could get that is still more a tractor than a garden tractor (although some who don't own one would argue the point). It's lower, has smaller tires, shorter, narrower, etc. It will go into places you couldn't fit a larger unit. It is probably ideal for 1-5 acre properties, or places where smaller size, lighter weight and lower ground clearance are an advantage. It's easier to transport. Maybe most different is a BX23 comes with a backhoe that would be an add-on with the 4200.
You haven't told us anything about what you need a tractor for, so the advice you get about which type of tractor is best really doesn't mean very much to your situation.
By the way, both JD and Kubota make superb tractors in the "compact" size (i.e. the 4200) and the "subcompact" (i.e.the BX23) size ranges.
   / bx23 or jd4200 loader and backhoe #15
I never said they were the same. As I said twice:...it depends on what he's using it for. bigger is not always better. i know this from experience.
Does he need a BH?..if so the BX has that standard. Hydro? BX Standard. 4x4, BX standard. Does he need any of this?...I don't know. If he has to lift a 1500# tiller, a BX isn't his machine...Just sayin.
I'm having difficulty understanding why you are taking this so personally.
   / bx23 or jd4200 loader and backhoe #16
Funny, I was thinking the same thing about your inability to comprehend the half the tractor thing.
   / bx23 or jd4200 loader and backhoe #17
   / bx23 or jd4200 loader and backhoe #18
I will add my perspective this issue. The BX is a fine little tractor. Wish I had one. But, my 4200 could pick it up as ballast and not even break a sweat.
   / bx23 or jd4200 loader and backhoe #19
Buy the one that best suits your need. Good luck with your purchase.
   / bx23 or jd4200 loader and backhoe #20
Original poster has apparently moved beyond the specific models discussed in this thread and is looking at others. Moderator... time to close this one?
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
2021 FREIGHTLINER CASCADIA SLEEPER TRUCK (A54313)
2021 FREIGHTLINER...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
