BX23 Temperature gauge - what's a normal range?
   / BX23 Temperature gauge - what's a normal range? #1
Speedy7
North East MA
Kubota BX23
BX23 Temperature gauge - what\'s a normal range?
I've only had my BX 23 for a month or so, and I've not seen the temperature gauge go more than a 1/4 to 1/2" from the lowest setting. Is this normal? Other than two mowings in late October, the rest of the 20 hours or so have been with FEL grading work at 1/2 throttle or so. Thanks!
SP
   / BX23 Temperature gauge - what's a normal range? #2
Re: BX23 Temperature gauge - what\'s a normal range?
That's about where mine runs at.
Ron
   / BX23 Temperature gauge - what's a normal range? #3
Same here w/ about 100 hours. Mine runs a lil warmer when mowing, but never past 1/2 mark.
Russell in Texas
   / BX23 Temperature gauge - what's a normal range? #4
Diesel engines run cold, unless they are working hard. Hard is a key word. When they idle, they actually cool down. My gauge runs at about 1/4 when mowing full speed. Idle it for 5 minutes and it drops below that.
Thanks for all the responses! Once I get past 50 hours, I'm more apt to run at higher throttles, but wanted to keep it under full throttle for now. Glad to know the low temperature is normal.
   / BX23 Temperature gauge - what's a normal range? #6
My BX-23 (about 270 hours) runs with the temperature needle just touching the left side of the little "crankcase" (or whatever it is) symbol in the middle of the face.
That's for "light duty" such as FEL work, pulling/pushing the box blade, etc. Running flat out with the brush hog on a 90-degree day the needle almost gets to the middle of the scale. /forums/images/graemlins/cool.gif Under those conditions, I always let it run at a fast idle for several minutes to cool down before shutting it off.
   / BX23 Temperature gauge - what's a normal range? #7
Just a bit under half way.
   / BX23 Temperature gauge - what's a normal range? #8
In winter doing FEL or BH work it registers about 1/4 of the way.
In the heat of the summer running the 60" MMM in the tall stuff and the screen half covered in debris it gets up to 1/2 way to alittle higher.
When it gets this hot it can take upto 3 - 5 minutes at "smooth" idle AND with the screen blown off to cool it down before shutdown.
In the current cold weather, the temperature doesn't get to more than 1/4 on the gauge, often even less. Is it fair to assume that no cool down period is necessary before shutting down at these temperatures?
   / BX23 Temperature gauge - what's a normal range? #10
Hmmm. I've got a new L4400 with about 25 hours on it. Even in August pulling a 7' mower in 90 degree heat my temp gauge never goes higher than the first little mark, which is just up about 1/4 _inch_ from the bottom. You can barely tell it has come up at all. Running it in 45 degree weather it does exactly the same even doing heavy FEL work. Wonder if something is wrong? It runs, starts and restarts great.
   / BX23 Temperature gauge - what's a normal range? #11
Interesting, I would think that the thermostat in the motor would keep the temp stable no matter what you were doing, maybe a little hotter if you are really working it. Most of our tractors are not continually working at max load, at least not pulling a mower. After recharging my anti-freeze this past weekend I noticed the previous owner removed the thermostat or it is stuck open. Warm water started circulating within minutes of startup. Luke warm that is.
   / BX23 Temperature gauge - what's a normal range? #12
Yes, I would think the thermostat would keep things stable and mine does. It never does anything but what I've described. Makes me wonder if my thermostat is stuck open. Do these tractors have thermostats like cars, just sitting there at the end of the hose? If so I can check it myself.
It is my understanding that a gasoline engine runs best at a certain temp, which is not necessarily as cool as the cooling system can make it. I wonder if this is true of a tractor diesel? In other words, if my stat is stuck open am I hurting anything?
   / BX23 Temperature gauge - what's a normal range? #13
At a 1/4 gauge reading or lower your very safe in just shutting down. That would be what I consider the normal operating temp on a BX.
I would recommend a short low idle period, say 30 sec's or so before shutdown to allow all the fuel, oil, hydro and water pressures to lower a bit. I don't have any brilliant scientific reasoning for this, I remember being told this way back in the day so I've done it on every engine I've owned since and it just seems right. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
It really takes a very hot day and tall thick grass to get my coolant temp up that high, most times it stays consistantly at about a 1/4 gauge reading.
Vofandt
Hmm, that's similiar to me, except that I got it too late to experience hot temperatures. Though, when I did mow in low 60's weather, it did seem to get a bit warmer, but these days in New England weather, it barely comes up 1/4 inch from the lowest mark.
   / BX23 Temperature gauge - what's a normal range? #15
Well yours is new so probably it's ok. Crank it up cold with the radiator cap off, idleing it should take quite a while to feel warm water, several-5 minutes (idleing). My guess is the open range of the thermo is about 180 or 190 like most engines. I haven't found a spec on this. Maybe I'll boil the new one to test it.
Probably won't hurt like this but all engines like to reach an operating temp and stay there, keeps the metals and such at the same temp and less expanding/contracting. Tractor, car not much different in that respect.
BTW the local dealer wanted $26!!! for a new thermostat!!! Bad part is $16 online at TS. When I get it I'll see if there is a temp stamped on it. Should be here tomorrow or Friday.
   / BX23 Temperature gauge - what's a normal range? #16
</font><font color="blue" class="small">( It is my understanding that a gasoline engine runs best at a certain temp, which is not necessarily as cool as the cooling system can make it. I wonder if this is true of a tractor diesel? In other words, if my stat is stuck open am I hurting anything? )</font>
Definitely Even with them not stuck diesels can overcool. Ever notice those canvas grill covers in winter? But I'd guess you would notice it if serious. Smoking, power loss, clatter, etc.
My thermostats tend to stick shut (unlike my mouth)...
Russell in Texas
2009 Ford F-150 Crew Cab Pickup Truck (A59230)
2009 Ford F-150...
FENCE PANELS (A58214)
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
UNUSED RAYTREE RMSC78-78" HYD SOIL CONDITIONER (A60432)
UNUSED RAYTREE...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
