BX2350 3 pt. spread width?
   / BX2350 3 pt. spread width? #1
bravo36
Dallas Metroplex (Lake Lewisville)
BX2350
Tractor is in storage shed several miles away, and I was trying to order a 3 pt. hitch/drawbar. I have the option of 20" or 26" I think.
Thanks in advance
Kevin
   / BX2350 3 pt. spread width? #2
My BX24 will open up to the Cat 1 26", but very little more. I just put on a draw bar and measured it.
   / BX2350 3 pt. spread width? #3
You can use either.
The advantage of the 26 is that the 3pt arms will remain closer to the tractor, if parking in a tight spot is an issue. You will also find that the 26 will bind as you raise it, if properly tightened.
The 20 leaves the 3ph arms extended further.
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2014 FREIGHTLINER...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
Hot Pressure Washer Trailer (A59228)
Hot Pressure...
UNKONW  SPOOL TRAILER (A58216)
UNKONW SPOOL...
NEW Woods 6ft Finish Mower (A56438)
NEW Woods 6ft...
