BX2350 3 pt. spread width?
   / BX2350 3 pt. spread width? #1
bravo36
Dallas Metroplex (Lake Lewisville)
BX2350
Tractor is in storage shed several miles away, and I was trying to order a 3 pt. hitch/drawbar. I have the option of 20" or 26" I think.
Thanks in advance
Kevin
   / BX2350 3 pt. spread width? #2
My BX24 will open up to the Cat 1 26", but very little more. I just put on a draw bar and measured it.
   / BX2350 3 pt. spread width? #3
You can use either.
The advantage of the 26 is that the 3pt arms will remain closer to the tractor, if parking in a tight spot is an issue. You will also find that the 26 will bind as you raise it, if properly tightened.
The 20 leaves the 3ph arms extended further.
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
Chariot 12' Box Trailer (A59814)
Chariot 12' Box...
2014 FORD F-150 STX EXT CAB TRUCK (A60430)
2014 FORD F-150...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
