Mowing BX2350 Mid-Mount Mower Height Adjustment
   / BX2350 Mid-Mount Mower Height Adjustment #11
:eek:And I thought I was just so stupid. Guess I have some company here. Deck height in centimeters...fore and aft.... Blade height fore and aft.....Anti-scalp wheel height...fore and aft. Left and right. I got numbers that are generally reasonable and agree that this MMM wasn't right from the dealer. But how about some general rules for adjustment. For example...the front blade height should be higher than the rear blade height. Right? ....by about 1/2" or less.
As to the full moon, it has been cloudy and raining here so long that the moon nor sun don't shine. I guess this leads one to do crazy things.:confused2:
   / BX2350 Mid-Mount Mower Height Adjustment #12
It took me a full case of beer and the owner of a competitive tractor dealership to get my deck within 1/2" of being level. He told me that he had never seen such a dumb design for adjusting a deck. I occasionaly check how high the blades are off the concrete drive and use Kentucky windage to adjust the knob to meet what height I want to cut. As others have said if you want your yard to look that good I think that you should have bought a "lawn mower". But then again most lawn mowers don't have a beer holder like my tractor. I think that helps me justify when the yard doesn't look the best. I blame the beer.
   / BX2350 Mid-Mount Mower Height Adjustment #13
I am into my first season of mowing with my bx-24, and i have wasted many hours over the last month trying to level off the deck. I finally got it close enough and said the heck with it, I took out the machine and cut my side lawn. I looked it over and it looked good so i cut the front yard it looks acceptable to me. I know it is still not to spec, but enough is enough.
   / BX2350 Mid-Mount Mower Height Adjustment #14
Maybe I'm just lucky, but I was able to adjust my 54" mmm (bx2350) in about a half an hour. It was a good bit out of adjustment from the previous owner, but is now darn near perfect. Some tricks that may help: Make your adjustments while on a level, flat, concrete floor. Have the tractor set up the way you will be cutting the yard, such as removing the loader and weight bucket before making adjustments. Properly set all tire pressures before making adjustments. Each one of these tips if ignored can easily introduce a 1/4" or more of change in the way you tractor "sits". As mentioned by others, don't worry about trying to make the cutting height match what the knob says. That's just crazy talk!
   / BX2350 Mid-Mount Mower Height Adjustment #15
BX expanded pretty much hit the way my deck works on the head. It cuts level, pretty close to the height it should, but it wouldn't lock in the top position to save my life.
   / BX2350 Mid-Mount Mower Height Adjustment #16
After searching some more posts, it appears that I made an error in my previous post. Apparently the front tip of blade height should be not higher but a smidge lower than the back tip when parrallel, i.e. about 1/8" of an inch. Now, I feel better that I haven't mislead anybody. But if you can measure 1/8" of an inch differance, you must be Houdini.:D
   / BX2350 Mid-Mount Mower Height Adjustment #17
I think alot has to do with the deck also. Are they using the right deck or did they modify a deck from say a BX22 to fit a BX24. If I recall Roma was looking for a BX22 deck and was going to cut and reweld parts. That may throw off adjustments in itself.
   / BX2350 Mid-Mount Mower Height Adjustment #18
I also have a BX2350 and have tried to attach the mower deck. I am having difficulty with the height adjustment. The book I have is not too helpful. Are there additional adjustments to linkage that I need to do? Please advise
2020 KUBOTA RTV...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
Toro Workman Utility Cart (A51694)
Toro Workman...
