BX2360 54" deck blade removal
   / BX2360 54" deck blade removal #11
Although an impact wrench can do the job, be careful because the tendency to hold the blade with your hand or not at all can get you hurt if a blade makes a quick 1/2 turn and hits you.
All I use is a breaker bar and a 2x4 block. I recommend a 6 point socket because the head might be rounded already from ground or stone contact. The washer covering the blade is usually a wave washer which spring loads the bolt in tension. That means you should not need it to be very tight when you put them back on.
I never remove the deck. Just drive it up on some ramps to give yourself some working room and change them. On all my mowers, I have an extra set of blades so that I can pull them off and put sharp ones back on in one operation. On the smaller (48" deck) machine, I just put a chain on the FEL bucket and bring the deck machine and all up to working height. Standing up while working on the underside of a mower deck has its merits. If this takes you more that 10 minutes, you need to hire a professional. Yeah inspect the deck for paint chips and dog poop collections, but it shouldn't be the most time consuming job at the ranch.
UNUSED AGT TSOCPF48 MAST W/ 48" FORKS (A51248)
UNUSED AGT...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
(4) 55 GALLON POLY DRUMS (A51248)
(4) 55 GALLON POLY...
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
UNUSED AGT SA-FT HYD PALLET FORKS (A51248)
UNUSED AGT SA-FT...
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
