Volfandt said:
... From what I can tell, the major differences between the D905 and D902 is in the valve cover and different fuel injector pumps on each. This is probably where the additional hp is generated ...
I have tried on a several occasions to find out more about the differences between the D905 and the D902 engines. The differences are slight, and Kubota is almost silent on the details. From what I gather, the greatest differences are overall weight and exterior size - the B902 is about 25% lighter and a bit more compact than the D905. This would fall in line with Kubota's ongoing efforts to cut the production costs for the popular BX units.
The most puzzling thing to understand is why Kubota would claim that the D902 (found in the
BX24) is more powerful than the D905 (found in the
BX23 and
BX22), given that, according to Kubota, both engines have identical displacement specifications.
So let’s take a closer look at how the estimated HP was measured. Estimated HP is published at 2 different RPM levels for each engine. The HP for the D905 is available at 3600 RPM and 3000 RPM, while the HP for the D902 is available at 3600 RPM and 3200 RPM. Published HP at 3,600 RPM shows that both engines have identical power in all 3 HP classes ("Gross Intermittent HP", "Net Intermittent HP" and "Net Continuous HP"). However, differences occur when the HP of each engine is measured at the lower RPM level; at 3200 RPM the D902 "appears" to be slightly more powerful than the HP of the D905 which was measured at 3000 RPM. However, this "apparent" difference would seem to be an artifact of the differences in the RPM ranges employed rather than an "actual" HP difference.
It seems to me that Kubota's claim that the
BX24 is more powerful than the
BX23 or
BX22 may be the result of an unfair comparison between the D902 and D905 engines. It is not entirely clear to me why Kubota would choose to advance this misleading claim. Might this be a simple oversight, or could this be a strategic marketing ploy to sell more BX24s?
I invite TBN members who who are more knowledgeable than me to shed light on this puzzling HP claim.
