BX24 Finally Has a Proper Roof
   / BX24 Finally Has a Proper Roof #1
thavil
Platinum Member
Southern Maryland
Kubota BX24
After almost a year of my tractor sitting under a make shift roof and sorta getting wet, I finally purchased a new 12'X24' garage. Now I need a proper ramp (couldn't wait to put it inside, so I used car ramps) and shelving to put inside. The first picture was it's former home. Now I can finally use my BXpanded backhoe dolly the way it was intended and not on plywood on the grass.
   / BX24 Finally Has a Proper Roof #2
congrats on the bx new home. ;) Next you will be adding heat right ?:cool:
Before next winter, I hope so. I need to run electric and then add lights, plugs and fans. Also need to put in some insulation.
   / BX24 Finally Has a Proper Roof #4
Tod,
That is awesome! I bet you sleep better at night.
Now when you are not at the meetings, I am going to have to jimmy the door instead of cut your pad lock!!!:D
Dean
Tod,
Dean
The mean guard dog in the picture will get you if you get near my garage!
   / BX24 Finally Has a Proper Roof #6
Nice Work!
I will be moving soon, we have an offer on our current home (time to downsize a bit), and I will be giving up my 20 x 40 pole barn. I am curious, is that a prefab garage, or kit?
   / BX24 Finally Has a Proper Roof #7
It looks lonley in there, but I bet it will get crouded out in about a month!
tom
Nice Work!
Thanks for the compliment but I really didn't do much to get it in place. It's a prefab garage ($4100 with free delivery) that I bought at one of the roadside shed dealers. I think it was made by the amish and they do great work. I cleared the area of any sod and then had 12 tons of 3/4" bluestone delivered and I spread it about 6" deep with my BX. I did have to remove one fence post and 4 boards to get it in my backyard because I only left 11' 9" for my gate and the garage with 12' wide.
tom
Not any more Tom!! Most of my yard tools are now hanging on the walls, bought a 5 shelf storage unit, a pegboard with hangers, a 5'X8' rubber mat to go under the tractor and a few implements inside. Once I get a proper ramp, I will put my BH inside also.
   / BX24 Finally Has a Proper Roof #10
You chose well, all the comforts, none of the hassles! Just means more seat time available for other pursuits.
How thick is the plywood deck? Is it pressure treated? I am looking for a home for baby bota, don't want her in the rain.
300 Gallon Tote (A47809)
300 Gallon Tote...
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A45336)
2020 Ram 1500 4x4...
Dump Wagon (A47809)
Dump Wagon (A47809)
TOFT 680 Hyd Hammer (A47809)
TOFT 680 Hyd...
Polaris SXS Side-by-Side (A47809)
Polaris SXS...
MLE 4188CR Clean Room Scissor Lift (A44571)
MLE 4188CR Clean...
