BX24 - I need education on grease
   / BX24 - I need education on grease #11
Frosstoise,
Check the tip at the end of the hose. Can you adjust or rotate the tip, loosen the
zerk jaws. If you have an adjustable hose tip simply loosen the adjustment and you should be good. If not, replace the tip with the adjustable type.
   / BX24 - I need education on grease #12
I have had the same problem as Frosstoise. I found it almost impossible to disengage the gun nozzle from the grease nipple so I asked a dealer how their mechanics did it. I was told to make sure the nipples were clean and that as the nozzle was used more it would become easier to disengage. Not very helpful. The adjustable nozzles sound like a good idea. Where can you get them? The only tool I have found helpful is a heavy duty long nose pliers with a 90 degree bend. These enable you to get a good grip on the nozzle to pull it off.
   / BX24 - I need education on grease #13
The adjustable jaws for the grease gun tip will allow you to use a flexible line off of your grease gun and lock the zerk to the gun. Just loosen the tip, put the tip on the zerk then tighten the tip on to the zerk. This is very useful if you have a dirty zerk that is not taking new grease easily or the zerk is in a poor location and the tip keeps slipping off the zerk.
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A53473)
2016 RAM 5500...
2006 John Deere HPX Gator 4x4 Utility Cart (A53421)
2006 John Deere...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
7022 (A50322)
7022 (A50322)
2011 FONTAINE 48 FOOT STEPDECK (A53843)
2011 FONTAINE 48...
BUSH HOG 1815R1 BATWING MOWER (A51247)
BUSH HOG 1815R1...
